How bloody hot is it today,,,the bloody news said it was the 3rd hottest day for this time of year ever,,,,,Glad I have a swimming pool and air-cond,,,,.
I can't get in the garage to change the rear discs and pads,,,,maybe this weekend if I'm lucky.
Neil.
https://www.sau.com.au/forums/topic/9549-hot-as/
Yeah it was definately hot, though i programmed the airconditioning to turn on at 8am so it was nice and cool inside all day.
Here's todays temperatures from the Weatherzone site..
http://www.weatherzone.com.au/misc/summaries.jsp
Was 45 in my aera :eek:
https://www.sau.com.au/forums/topic/9549-hot-as/#findComment-144931
Some little f*ckn monkey decided to start a fire near my house! Did night shift last night and trying to sleep in this weather is hard. Then add the noise from the choppers and emergency crews I couldn't sleep. If I find that monkey I'm gonna skin his testicals!
https://www.sau.com.au/forums/topic/9549-hot-as/#findComment-144946
Our poor Car Detailer was under a tin roof all day,,,he had to get 3 cars done,,,,I took the poor bastard down the pub at lunch time and poored 4 VB's down his throat. He backed up after work with a couple more.
BEER is Good
Neil.
https://www.sau.com.au/forums/topic/9549-hot-as/#findComment-144947
Originally posted by Silver-Arrowz
Grrr.... :)
advantage of being team Vorthside :)
NO WAY,,,Westy's Rule,,,, I'm a Westy,,,,8 steps out the back door is a 14 x 7 Metre Pool,,,,no sand,,,no Idiots,,,I Rule my backyard and the BEER fridge is on the way out and on the way in.....
Neil.
https://www.sau.com.au/forums/topic/9549-hot-as/#findComment-144999
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
