What I am saying is that the vortex here is BP ultimate. Its actually 98 ron bp fuel.
The reasoning this guy gave me for caltex not calling it vortex 98 is because the real ron figure can be anywhere between 95-98. BP dont care that its often lower then 98, but caltex promise it to be atleast 95, hence the 95 ron rating.
I still find it all a little wack, were the catlex premium pumps running out at the same time as BPs?
Edited by noise
I used vortex when there was no ultimate and some caltex's were running out. Attendant said that they wouldn't have any until middle of december, thought it was a bit of a coincidence that it was the same time ultimate was meant to be back.
Maybe our vortex is just ultimate that's been cut with lower grade fuel to make it 96 ron.
I've visited Dulux factory and apparently they manufacture competitors paints as well (a specificed ingredients list is provided by the compititor), because it is relatively expensive to buy the machinery, so competitor just 'piggy back' of Dulux...this is why even though more ppl chose to buy rather cheaper generic brands, Dulux never went bankrupt...
imagine that there is only 1 refinery in W.A....so the companies, BP, caltex, other fuels basically come from the same spot, only that different companies have their own "secret ingredient" such that the refinery have to refine these petrol according to the clients specification.
now what if the refinery is owned by BP....BP will process fuel for the competitor..and the competitor sell cheaper fuel ... However, BP needs to keep it's image up..and hence they produce the only 98 Octane Fuel in W.A....BP domination...muahhaha
probably in the case of Eastern State, the amount of population is enough for each individual companies to set up their own refinery and keep it profitable...therefore 4 different 98 octanes to choose from... BP does not dominate the market anymore....
This checks out with the unavailabity of vortex in the same timing as Ultimate...but then again I might be wrong...don't have the fact sheets on me....
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
