hey Darren. the bosch pump has worked great for me so far. i know Nightcrawler has had some problems with the 040, though. then again i have heard bad things about the walbro aswell. do a search in 'forced induction performance' too, there are quite a few fuel-pump threads that mention these two pumps. :P
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738637
Darren,
I have had a bosch o40 or 044( cant remember) for many years now ( in fact martin d did an artical in hpi on how to do a in tank fit using our car as guinea pig for fit / photo's_at tilbrook's ).These are quite good pumps, we have had no trouble however they are on the noisy side with no music pumin!
Regards,
SKYLINE (Kym)... B)
Edited by skyline
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738783
Cheers guys just read the forced induction section and it seems they are quite similar in performance whilst the Walbro is some $60 cheaper and the bosch 040 can have some issues with fittment(eg the 1/4 tank which could cause surging issues). Cheers Kym might have to find that HPI Mag as i will be doing it DIY styles.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738816
hey, the "1/4 tank" problem with the 040 is due to incorrect fitting of the pump in the first place, nothing to do with the pump itself.
sydneykid is not a fan of walbro pumps (which is enough for me, to be honest) and another guy i spoke to who has an escort race car said "nothing but bosch". you should be able to pick up an 040 for about $220-230 or less.
how much power are you planning on making? the 040 will be fine up a point but you might need something bigger. but then don't go for overkill or you get noise and overheated fuel (depending on your setup)...
cheers
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738929
Yeh the 040's are about $235 delivered where as Walbro are $175 delivered, yeh i was originally more keener on the 040 after hearing about issues with the Walbro, but now they seem to be quite similar, Thinking i might have to spend the extra cash and get the better quality one(040).
After AFM and a FC retune should be up around the 210-220kw mark which i will be happy with for a while.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738953
i got my 040 from Greddy in the Trader section for 230 delivered, came all the way from great brittan.
i heard about that surging problem, on the bottom of the 040 there seems to be no nozle to connect that pick up hose thingy?? as all the other pumps habve them that maybe be the problem. i DUNNO really. :)
havent fitted it yet coz im a slack bastard :D
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1739312
I took out my Bosch 040 that was noisy as hell (especially when you have below 1/4 tank or the weather is over 30 degrees) and put in a Walbro 255lph. Have had the car dynoed with both pumps and power is the same, at the same fuel rail pressure. I had the Walbro rechecked just the other week, after hearing disparaging comments from some SAU users, but Turbo Tune said the pump gave 'more than enough' fuel pressure for 200rwkw through 4 x 550cc injectors. They could not fault the pump whatsoever, yet I did have a 4 month old Bosch 040 fail year back.
Edit: Like DriftR says, the oem style mesh pickup of the Walbro is far more reassuring than the Bosch pump setup - the Bosch has no filtering and the pickup is not as low down (which could explain people's surging problems).
Edited by Nightcrawler
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1739315
Having an 040 installed right at the moment (with z32 afm, fpr, fuel lines, sitc, direct battery feed to fuel pump, etc yadayadayada), and retuned on the safc.
Hopefully pick it up tonight...
Yah, have read that Walbro isnt that great but is serviceable, big thing there is the amount of cheap chinese copy Walbro pumps that are out there. Nasty stuff apparently. Read a lot about that. But also read genuine items flow like a 040.
With the 040, you must install it as low down in the tank as possible, to get around that 1/4tank surge 'feature'. Due to the pump not having a 'sock' like the 918-series. Install low down with a custom bracket, and that wont be a problem.
I got my Bosch 040 off ebay (victoria, fordefi) for $198 delivered, with 12month warranty.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1739943
I got my 044 installe din the 32 by Shaun. Cant hear it at all, excpet on hot days it gets a little noisy.
Id expect them to say something like that regarding a skyline :)
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1745863
I needed to get a new fuel pump after I did a SR20DET conversion in my Silvia, and went for the Bosch 040. It makes a buzzing noise every 5 seconds or so on idle usually, but can't usually hear it much when driving normally. As others have said though, it's almost constant noise when you are low on fuel. Doesn't bother me, I just don't pay attention to it.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1745866
same with mine too. shaun installed it, and it never makes a sound. except yesterday when the weather was warmer than usual, i could hear it.. why is that?
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1746228
When the weather is warmer your fuel is warmer. When the fuel is warm it expands. When the fuel is warm/expanded the pump has to work harder to pump the same volume of fuel, compared to a cold day when the fuel is more dense. The pump working harder is the noise you hear.
When I had my 040, on any day when my car had been out in the sun for a while and the temp was over 30 degrees, the buzzing noise was horrible.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1746259
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
