Item: gtr front bumper
Item Condition: damaged but repairable
Reason for Selling: just bored of the look.. :P
Price and Payment Conditions:210 ono. if to be repaired, then add on xtra cost. i can get a quote for you from my friend who works at jetspeed.
Extra Info: front bar onli. will consider selling the rest of the kit as well if i get a decent price for it
Contact Details: can call me on 0433 288 468 or just post me.
some pics attatchd for all to see
https://www.sau.com.au/forums/topic/96021-fsgtr-font-barpossibly-whole-kit/
im trying to get prices for postage for those in need of it. ive previously had enquiries alredy from Brisbane and Perth [you know who you are hehae] and yea.. will do the best i can to get back to you fellow people!
  • 1 month later...
sorry guys...the offer is no longer. ive decided to keep it because now my car is dead in a garage, and if i sell the kit then it looks like a heap of junk kit-less.. :D so, just going to keep the kit for now, but might reconsider it later on..
OMG..by the way, i had it checked out and my firend says it's a genuine GTR kit :P ....hehe...lucky i didn't sell it yet aye...anyone got any idea how much its worth now?
u wanan bet?...mine IS plastic, hence that is why i'm in search of a plastic welder to repair it. plus it has the NISSAN stamp inside it as well. i'll take it to a nissan dealer to look at it if i must....which i dont relli wanna do hahah
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
