R32 GTST STANDARD COLER AND PIPES $50
R33 GTST DIFF NON ABS $300
2 RIMS ONLY 17X9 $80 5 STUD
R33CENTER CONSOLE BACK HALF NO LID $30
R33/R32 STOCK AFM TO TURBO INTAKE $20
R33/R32 HKS CROSS OVER PIPE $30
R33 DASH TRIM BEHIND GLOVEBOX $10
R33 DRIVERS SIDE LOWER DASH PANEL WITH FUSE BOX COVER $20 ON HOLD
R33 LH KICK PANEL COVERS COMPUTER $10
R33 INSTRUMENT CLUSTER SURROUND $10
R33 PASSENGER SCUFF PLATE $10
R33 PASSENGER A PILLAR TRIM $10
R33 GTST STANDARD CASTOR RODS $20
R33 GTST FONT HUBS SOLD
Edited by burko1
https://www.sau.com.au/forums/topic/96090-garage-sale-skyline-parts/
oooo
and
does the instrument cluster surround have the clear plastic?
ill definately take the lower dash panel!
where are u located ill pickup pm me.!
hey
do you have the surround that goes around the stero, and it goes all the way around the instrument cluster that one peice of plastc? is that what you were referring about the instrumnet plastic surround?
also i dont suppose you have handbrake boot, gear stick boot, and a non air bag series 1 steering wheel lying around do you?
let me know
hey
let me know
NA NONE OF THAT SORRY
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
