hey all,
was good to meet wrxkilla out there.
i made it to the top 8 out of a 70 odd car field in DYO class. Car ran like a pig all day till it got to when it counted and then went like a dream. dialed in 12.25 and ran consistent 12.27's then broke out after backing off at half track so it was gonna go fast that pass...
Just got some injectors highflowed for it and its going to the coast saturday for a tune with different fuel and more boost...
https://www.sau.com.au/forums/topic/96101-street-car-shoot-out-just-passed/
Nice work, congrats...
Whats actually done to the engine/turbo etc?
ABHhHA h Ah HA hHA hAHh AHHAhHAhAH hAHAhAhahaaaa
Turbo :D
see here:
http://www.skylinesaustralia.com/forums/in...showtopic=35764
yeah john was nice to meet you mate, well done love your car.
i got knocked out in the second round by red lighting myself against the r30 rb30tt skyline! lol
infact i have a video of you and me in the qualifying rounds?
want me to link it up?
Was the R30 mental? Just my mechanic was ripping one out of an R32 and putting it in something else from memory, just I didnt get to see the something else.
Anyway, nice work John. Will be good to follow your progress thru it. Wave that flag!
yeah that would be great if u could.
the website is www.dealphotography.com.au
here is a pic of the rb31.
he had a dial in time of 11.57, but i saw him and have video of him running a mid 12.
:P
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
