with results like that i'd say there are a few options:
1) your guage is stuffed
2) your cam timing is extremely out
3) your valves are not seating. at all.
4) you forgot to install piston rings.
it should be up about 150 or so for most petrol engines.
i have found opening the throttle body to make no difference, but hear you should do it?!
Freeman, your next step should be to do a leakdown test on the cylinder thats low, and that will tell you if its ok. 10% leakdown is fine.
RU34ME, how are you doing the test? how many times are you cranking it over before you take the reading?
Yeah i was planning to do a leakdown before i bought it but they didn't have the equipment on hand at the time unfortunately...
Hey are your plates SLY33? Mine are SLY25L lol.
Yeah opening the throttle body shouldn't make any difference
