Recently replaced all fluids in my R33 GTR with Redline Synthetic and since then a lound crunching sound is coming from the trans when reversing at low speed on lock.
Mechanic and redline assure me this is normal and is called " DIFF CHATTER " or ' clutch chatter '.
Want to know if anyone else has had any experience with this ??
sb..
https://www.sau.com.au/forums/topic/96238-diff-chatter/
axle-tramping... Like... umm.. the rotation of the diff affects how the rear end squats or lifts when you're gunning it.
Mine (stock) will chatter and jump all over the place if I light it up in the wet in 1st gear, but if I switch to 2nd, it's all smooth sailing (sideways).
I get the chattering if I reverse quickly or give it some steering at the same time.
Maybe i'm horribly wrong, and it's just a LSD diff thing... I don't know a lot about what a 1.5-way diff is, but i've heard those specs a few times before. I know what open, LSD, locker, active LSD all are, but this "way" business could be something related?
https://www.sau.com.au/forums/topic/96238-diff-chatter/#findComment-1746517
yeh if ur clutch doesnt have a spring centre to damper the grip of the two faces when releasing the clutch it will send a shudder or jolt down the drivetrain line which in turn can cause something else to engage too quickly or too roughly which may cause the shudder your experiencing.
The spring centre is purely to help take up some of the initial jolt when the clutch is released. Makes for a smoother drive normally. My car has a sprung centre and its beautiful, the race car has no sprung centre and its really jolty and clunky, makes you think something is wrong with gearbox when u release it.
https://www.sau.com.au/forums/topic/96238-diff-chatter/#findComment-1755799
Don't mean to hijack your thread mate, but my car does the same sort of thing. I'm under the impression i have a locker diff, it's just very inconsistent on when it wants to make some noise. It gets people looking at my car for the wrong reasons. :D
But what R33 racer has said has me thinking now, as "sometimes" I can feel the shudder actually beneath me from the rear of the car, other times it's just at the back. I have had the oil changed to redline lightweight, but i need to change it again to a heavier oil. Lightweight makes it good for less friction, but i don't need it for racing!
https://www.sau.com.au/forums/topic/96238-diff-chatter/#findComment-1758722
Guys this link might be of some benefit to you.
I am also a Rex club member.
Please see this link.
Note sti05's posts and STIRA and lastly closed deck who owns Urban Racing Developments
http://www.wrx.com.au/forum/viewtopic.php?...ghlight=redline
Edited by PATR33
https://www.sau.com.au/forums/topic/96238-diff-chatter/#findComment-1759375
link doesnt work.
The original post sounds like its just the diff noise from the change in oil..other people have mentioned their diffs clunk more with redline oil in it more noticably in reverse and or while some form of steering lock is applied. The oil maybe lighter and have a tendancy to increase any diff noise rather then absorb or dissipate it.
But from what im hearing here about the clutchs...sounds like its a matter of when u engage the clutch without enough revs it clunks and carrys on also...forgot to mention that part previously. Especially if its a ceramic or brass button clutch..and even more so if its a non-sprung centre clutch.
https://www.sau.com.au/forums/topic/96238-diff-chatter/#findComment-1760936
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
