what the hell are u on about?
as merlin and a few others have already said.. stock R32, R33 and R34 turbos are ALL ceramic NOT ball bearing.
wtfs a ceramic ball bearing turbo?
why do you think the most common upgrade is TO a BB turbo like the VG30?
OK OK OK FOR ALL THE NEWBIES OUT THERE THIS IS IN NO WAY SAYING YOUR ALL DUMB ASS's
ok.. r32 r33 r34 standard turbos ARE ALL BUSH BEARING with a CERAMIC EXHAUST WHEEL
and also from memory.. a vg30 turbo is bush bearing aswell :P
any other info feel free to ask
Wazz
Some of you guys are out of your freaking minds.
I have bought this turbo so it is no longer for sale.
It is on my car right now and works fine. A small amount of shaft end play is quite normal for these BALL BEARING turbos, and this one is fairly typical.
r32 turbos are bush bearing and have a metal rear and ceramic front, same as series 1 r33 turbo's, series 2 and on are full ceramic as for which ones are ballbearing? not sure, but i know r32 turbo's aint ballbearing standard, r32 turbos handle the most psi, followed by the r33 s1 turbo, fact being they have metal rear wheels and i can confirm this ive pulled shit of my car many times, ive even ran my stock turbo at 20 psi by accident for a few days and didnt realise and ran fine! lucky for my cooling, just waiting for my stock r32 turbo to die but it just dosnt seem to want to go! lol it has almost no shaft play!
but that said..
the turbo in that pic has been high flowed, it has a twin metal front wheel, its not standard looks the same as what is sitting in my wardrobe which has a $1100 highflow done to it. meaning ballbearing and full steel wheels! so u should think about increasing tthe price son :rolleyes:
Edited by nemz
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
