Hey all
I have an r32 gtr and want some advice on how to keep it within the 'stock' limits... so far it has a k&n a/f, x-force dumps & front pipe, std cat, and blitz nur cat-back sys. without the x-force pipes etc on it, it made 250rwhp (184rwkw) on standard boost.. hoping for 270rwhp with the x-force gear on it....
will i need to change the exhaust etc before selling it (within 2yrs) to be able to advertise as a nice, stock example??
any help would be great..
https://www.sau.com.au/forums/topic/96416-r32-gtr/
If you've already modified it, why are you going to sell it as a stock example...?
How are you gonna feel when you advertise your car as stock in 2 years time and i bring this thread back up...? If you are going to be dishonest, at least be smart about it.
A decent exhaust is a bonus on any car bought. Enjoy your car for how long ever you will than advertise it as it stands. If it's still in good condition and passes the buyer's tests, you don't have to lie about anything.
https://www.sau.com.au/forums/topic/96416-r32-gtr/#findComment-1748026
yeah.. i've just had a look and the boost restrictor (little brass plug with a 3mm hole in it??) is still in the line around a yellow stripe... i had it dynoed at 250hp at the rear wheels on standard boost!
ill look into getting a high flow cat.. i read in zoom that the standard one is quite good though... either way.. thanks heaps guys
https://www.sau.com.au/forums/topic/96416-r32-gtr/#findComment-1758452
look at getting the magic 4" type cats that flow more than a 3" high flow, dump pipes that divide wastegate gasses from turbine outlet
Not cheap things though.
K&N filter if you have stock airbox.
NGK iridium tip plugs
under drive pulley kit?
(power to weight ratio) take any extra weight out of your car, passengers, seats, dont run any more than 1/2 tank of fuel
https://www.sau.com.au/forums/topic/96416-r32-gtr/#findComment-1758463
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
