Hey guys,
i been using the stock suspension and spring for some time but they started squeaking and feels bad now so i guess im looking for new ones.
Most of the time i go drag racing so just want to hear your suggestions on what i should get,dont really have the funds to get a top coilover system.Was thinking of koni or kyb shocks with some sorta performance springs?
Apart from the actual shocks and springs,what other stuff do you guys do to make your r33's more stable,launch better,oversteer less, thanks in advance for any advise,im really in the dark here.
Outlaw
13.6
https://www.sau.com.au/forums/topic/9660-gtst-suspension-tune/
Something like Koni adjustable shock-absorbers with HKS springs would be a very nice package, but for that money you could probably get a set of 2nd-hand coil-overs. Coil-overs will remove any nice soft ride that the car has, if you are thinking about it then get someone to take you for a drive in a car with coil-overs, it makes for a very bumpy ride and you might not like it.
See'ya:burnout:
Coilovers will kill your drag racing career. They are too stiff and won't let the car squat and launch. Mine just axle tramps off the line when I try and launch it (Drummond Motor Sport coilovers), but that's doesnt' bother me too much, as I'm a 95% track, 5% drags kind of guy.
Best suspension for drags is your standard springs and shocks, combined with a subframe and diff bushes (pineapples as people like to call them).
A good compromise for soft ride, ability to squat and launch, as well as good upgraded handling for everyday driving is the full whiteline package. They are EXCELLENT value.
http://www.whiteline.com.au
Good call Merli, my coil-overs are crap for street and drags, but brilliant for the track, there are designed as a full-racing coil-over, so I shouldn't expect a comfortable ride. Everyone I've spoken to rates the Whiteline stuff very highly and for a complete package I think it would give one of the best all-round packages.
All us Jap enthusisast are too quick to jump on the coil-over bandwagon, and they are great, but there are some drawbacks associated with them, namely comfortable ride.
See'ya:burnout:
Cool thanks for the input!
Yea i think ill go for a more normal setup but ill guess ill still get either koni's or kayaba because my stockers have called it a day,.There are some Drag Spec coilovers such as from veilside(exact specs with the record holder freak r32),and HKS,but far too expensive and not for a gtst i guess cause the setting is set for 4 wheel drive.
Yep ill definitely be looking for the pineapple and whiteline gear.Ive heard of anti lift kits,well ill go to a suspension tuning centre to check it out.
Yea i just got myself some bridgestone re-540s's.Its so sticky,you can hear the sound of sand sticking to your tires(just like the new road with tar sound)even on a normal road.I feel im more in control of the car,but i gotta warm em up a little bit before a serious run.
Just watch rear tyre wear when you start playing around with ride height. My R33 is only lowered 1.5in and it chews the inside of the tyres. I suggest getting the Cusco rear camber arm for the rear (JIC has one aswell) to straighten up those wheels unless you don't mind replacing rear tyres on a regular basis. In theory should give a better launch too. Radial tyres don't like big camber.
I fitted the Cusco arms to mine a few weeks ago as I am up for rear tyres and didn't want that to happen again. They look pretty trick to. I have Bilsteins alround and they work quite well.
you can have some increases in rear shock/spring rate, as long as the front is left fairly stock (small increases will be ok). If you are really keen on drag racing you can get a 90/10 shock setup on the front, pretty crap for going around corners but excellent to tranfer power to the back wheels.
Lowering the car is ok as well as long as you don't lower much more than 1inch.
Nah, alignment is sweet (I hope). I have had my car 16 months, got it aligned when I first got it, after I fitted the new shocks and after I fitted the arms recently. Front wear is good, just terrible inside wear on the back. I had a bit over 2 deg of neg. on one side and a bit under 2 deg of neg on the other side at the back. Way to much.
I got front and rear aligned all those times. Each time they set the rear toe to L +1.0mm & R+1.0mm. If anyone is using different please let me know. I am only going on what the "experts" tell me.
Alot of people with lowered skylines suffer from this though, IRS commodores are worse, some BMWs suffer pretty bad as well, as well as others.
hey Shuto Boy,
i have recently purchased a whiteline handling kit. Bloody unreal!!
My car doesn't only look 100% better than stock it has also increased corner speed y about 15-20km/hr.
my car has a bit of a harder ride but i think that is good. feels sporty. with car being lowered a bit (35mm front and rear) the camber has obviuosly been changed. Shouldn't really bother the rubber that much providing you drive spiritidly.
the car launches a lot harder to.
Other than suspension,
the other ways to make your car more stable, point better and have less body roll are:
Strut bars front and rear to stiffen the car
Sway bar to lessen body roll
Pineapples to lessen diff tramp
I am refering to the part in your post which says "....apart from suspension...."
Just my 2 cents....
Where, who and how much for this.
I droped mine 35mm and I too chew the insides.
I got mine through takakaira. I just had to buy something from there after I found that site! JMS also said they could supply them and I noticed PerfectRun has recently added them to there list of goodies. Takakaira ended up being the cheapest way to go but perfectrun isn't too far behind. Takakaira and PerfectRun also have the JIC version which is a bit cheaper. Both quality products I'm sure. UAS said they might be able to supply the JIC ones but I never got back to them to find out whether they could or couldn't.
Through Takakaira
Cusco $498
JIC $425
+ postage (checked 5min ago)
A bit $$$$ but if you intend on keeping your car for a while I think its worth the money. I can't afford new rear tyres every year just from normal driving.
MRE next time you guys organise a cruise I'll come down and you can have look if you like. Couldn't make Roma street had a birthday dinner thing to go to.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
