  • Replies 114
Posted Images
quite possibly that would just be from an external accelerometer than something in the ecu? what other things are on the dash? if theyre largely mechanical type things (rather than typical sensor readings from consult) then id say thats what it is
does it say anything in the service/user manual (if there is one?)
Edited by NewKleer
The R34's show the G-sensors digitally on the dash for 2000 models up, and mechanically for 98-2000 models.
The R32 GTRs and GTS4's have a couple of G-sensors around the place, but you don't get to see what they're doing. I think they would go to the ECU though.
I'm pretty sure the g-sensor would need to report to the ECU for ATTESSA functionality, unless of course there's a sperate unit/controller for it...
Also, just to confirm... HICAS is also controlled from the ECU? Or does it just manage the steering angle sensor and the like somewhere else?
Re: G-sensor ECU input for R32 GTR. The last few pages are the relevant section. It's the Autospeed article on the R32 from years back.
Thanks for the article, which for those that havn't read it, explains how to intercept the signal between the accelerometer (g-sensor) and the ECU. Which also allows for modification (i.e. piggyback system).
However, what I'd like to do, is read the sensor output voltage from the ECU (via the consult port)
Suppose we could try some reverse engineering.
trying to read g-sensor via consult port would mean reprogramming the ecu (and knowing how to do something like that). would take 5% of the time of that to just read the voltage directly from the sensor.
The documentation I have read implies that there *is* a consult port (that is, it had an id byte after a two byte initialisation)
it just doesn't seem to be wired up.
Of course, I could be wrong.
though it appears that all the computers get *all* their data as sensor voltages.... ahh, the possiblilties are endless
(when I make that attessa controller, I'll share it with confidence - as opposed to state my theory and get shot to pieces)
While I'm at it, I'll ask this question:
What are the inputs to the hicas computer, AND how does it control the pump (r32).
heck - the same with attessa. I have partial information on the input, none on how it controls the centre diff.
I suspect I'll need to get at it with a multimeter one day...
supposedly air con, hicas, and auto transmission can be queried via consult protocol, but ive never had success. i saw a table of whats supported in what vehicle, and i think the common cars only support ecu, whereas gtr and z32 (which ive never tried) support some of the others
Consult and Conzult work with AirCon, Hicas and Auto Trans in the Z32's. They each have their own seperate control unit but all read from the DDL.
quote=NewKleer,31 Jan 2006, 06:26 PM]
have released an alpha version of ecu talk while or work on the consult lcd
http://www.ecutalk.com
needs .net framework 1.1, links on the downloads page there
Edited by NewKleer
on my r32 gtr the hicas ecu wont respond to the initialisation unless there are delays between bytes but the engine ecu responds with no delays could be to do with the extra distance to the hicas ecu in the boot or even the different processor used by hicas, my ac ecu also remains silent with no delays but i have only just discovered
the need for delays and have not tested for the aircon delays yet.
i read that plms have to send initialisation more than once sometimes they are possibly not using delays.
my hicas responds to hex ff ff e4 with 10 then i send d1 f0 hicas then streams the error codes FF020000 ff start byte, 02 number of data bytes following, 0000 error code bytes ie no errors when ignition was last turned off
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
