I own a R33 and unfortuantly i can tell you that all my bass is trapped in the F#$%in boot.
There is a 12inch sub in there i swear. Its just the metal plate that separates the boot and the back seats blocks my bass.
It used to sound good in my previous car. 8-(
Anyone got ideas on removing it or cutting holes in it to free the bass...
Thanks. :uh-huh:
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/
if your sub box is ported then it won't sound as good as a sealed enclosure in your car.
at the moment i have an old pioneer 10" free-air in a sealed box (i know, i know, it's not designed for a box...) and it actually sounds a lot better than i thought it would.
which way is the sub facing? try facing it into the rear corners of the boot.
also make sure your boot is sealed properly.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-150456
Hmm, I suspect a better sub/subs and amp would make a huge difference.
I have 2xSoundstream Rubicon 300W with 1x600w earthquake amp.
There in the boot of the crx, which is in no way connected to the insided of the car.
More bass than you can poke a stick at....
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-152047
you wouldn't want to that plate contributes to some of the structural stability of your car.
besides... bass should pass thru the metal plate with relative ease as its not a dampening material.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-153459
My mate just put a sub in his and found that removing the factory false wall that hides battery, it mabe a very noticable difference. He is fabricating a new cover.
Me personally i beleive in speed. SKYLINES are performance cars not BOOM boxes. And before you ask, I have decked out my company van (owned by the company i work for, but in my care 24/7) with a decents audio system, including a 12 inch Rockford Fosgate sub powered by a PUNCH series R.F. amp.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-153680
No need to upgrade my system. Its the pump.
It's just it sounded better in my Hot Hatch than it does in my GTS, I guess thats to be expected though.
Ive spent over 4k on it and its all Alpine with a 12" Kiker and 2 x Big Kenwood Amps so i dont think upgrading is the problem.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-155183
Ah ok.
Still, with that type of set up, it baffles me how you can ask where the bass is...:lol:
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-155293
It's got me farked where your bass has gone. I have a Fusion fpw-1500 15" run by a Rockford Fosgate 250m2 monoblock amp, also in an R33. There sure as hell isn't any problems with bass with that, and it's in a ported box.
The Tool
Dunno what you mean by "a ported box won't sound as good in your car". Mine sounds fine, heaps better than my old sealed box, and is absolutely cranks with the low notes.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-157646
I put my old amp and sub into my 32 and was pleasently surprised at how well the sound travels through the metal sheet behind the chair. Not quite as good as my 180sx though but the equipment has aged and had a hard life since then so it may not all be the car. No way I would go to the effort of cutting out holes when it sounds perfectly fine facing the back of the car. Cutting holes or removing it alltogether is also illegal too as you are removing too much structural integrety of the car.
https://www.sau.com.au/forums/topic/9702-wheres-the-bass/#findComment-163861
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
