***PRICE DROP***
1989 R32 Skyline GTR
Reason for Selling:Have too many GTRs
Price and Payment Conditions:$23,300
Contact Details:0410 808 373
1989 Nissan Skyline R32 GTR 2.6 litre twin turbo
VIN# 6U9000 BNR32-003129
240 rwkW (dyno tuned at Boostworx)
NISMO 240 km/h speedo
Aftermarket ECU
BILSTEIN shocks
GReddy PROFEC B boost controller + GReddy boost gauge
M's airpods
Aftermarket exhaust
Aftermarket oil cooler reloctaed to front + all braided hoses
Recaro driver's seat
Front and rear strut tower braces
Enforcer alarm system + two key fobs
Omori water, exhaust & oil pressure gauges
NISMO shift knob
Nardi steering wheel (pictured in more recent photos- see page 2 of thread)
Braided brake hoses (not fitted- standard ones on car atm)
New Toyo T1Rs (travelled less than 1,500 km)
New clutch
New battery
New front & rear Bendix Ultimate brake pads
Front & rear discs recently machined
New front upper control arm bushes
New platnium spark plugs
Engine just had major service replacing all liquids (Mobil 1 & Redline oils) and filters.
Air conditioner was regassed.
Timing belt has been replaced
Dyno sheet + Service record available
Edited by writeoff
https://www.sau.com.au/forums/topic/97234-r32-skyline-gtr/
  • 3 weeks later...
  • 1 month later...
PRICE DROP
Will take the car to this weekend's SA cruise meet point 3 for any interested parties to view.
PM me for details.
Saw the car on the cruise, i would have bought it (if i had the money), my brother was interested (i think you spoke to him at BP before we left).....but he's working out his finance. Nice near car!
https://www.sau.com.au/forums/topic/97234-r32-skyline-gtr/#findComment-1994835
  • 3 weeks later...
C'mon guys. This car needs a new home.
Plenty of tyre kickers but I know you genuine buyers are out there.
Not interested in a trade as I have 4 cars already.
https://www.sau.com.au/forums/topic/97234-r32-skyline-gtr/#findComment-2047462
  • 4 weeks later...
***Price Drop***
$23,800
Guys this car has new Toyo T1Rs, new clutch, new platnium spark plugs, new battery, new upper control arm bushes & new brake pads. That's alot of maintenance items you won't need to replace for some time. The body is straight and clean - no dents.
https://www.sau.com.au/forums/topic/97234-r32-skyline-gtr/#findComment-2110690
  • 3 weeks later...
These are the tyres for those who don't know how good Toyo Proxes T1R are http://www.toyo.com.au/proxes%20t1-R%20page.htm
Am leaving for Germany in 4 weeks and would love some extra spending money. Will consider all reasonable offers.
https://www.sau.com.au/forums/topic/97234-r32-skyline-gtr/#findComment-2163101
  • 3 weeks later...
I'm off to the Nurburgring and then the World Cup on Wednesday so I won't be answering any posts or phone calls about this car until I return in July.
https://www.sau.com.au/forums/topic/97234-r32-skyline-gtr/#findComment-2229994
  • 3 months later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
