  • Replies 179
Yeah alright,
but I'm working all day tomorrow sooo.
MEET 6:00 pm SHARP XMAS EVE
Toombul shopping centre.
Under the air train rail line.
I hope to be on time so that we can fu<k off as soon as possible.
See you guys there.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
