only reason why i bought colover was so when im driving with the young lady i can see here boobs bounce
crap sydney roads are great if you ask me
only buy adjustable coilovers if
A) for boobies
B) for track work :lol:
everyone else is a wanker!!!
Edited by fatz
same here.. i refuse to pay tolls too! thats y i use parra road to get into the city..
yeah I used to use parra rd...4 times a week getting into UNSW for training but now I just use victoria rd/epping road and cross Anzac bridge. cuts the tolls out too!
As bad as the roads are (GTR with tein susp and f + r adjust camber) i cant get over the stupidity and lack of thought put into the organisation of roadwork crews.
If they have to block off 2 out of 3 lanes on a major road, why not start it at midnight? then finish before peak hour in the morning? (Obviously not practical when drying/curing is involved)
I travel very strange hours, and during the day when im out and about the road crews are digging holes and filling them in (not flat either more often than not), but the same road at 330am = empty?
Isnt it the RTA's job to ease jams? Not make them?
Goes to show the lack of care for the motorist from RTA.
Not sure where you're living, but can't say that happens around my neck of the woods.
Around here, road works start at around 20:00 - 21:00, and they're usually done by 02:00 - 03:00. I'd think that they should work through until 05:00, which will still give them time to clean up before the morning traffic comes in....and do a proper 8 hour shift.
Straight down Parramatta Road to where the clock tower is, make a left and head towards Ashfield - WELCOME TO LAND MINE TERRITORY! :P  Funny thing is that everytime I drive through there, I see more and more modified cars :D
Yeah this road is shocking! Frederick street! As I live near by I tend to use it a fair bit and my tein suspension really doesn't like it.
Do you use this road much Satanic? May have seen you around in the R34!
yeah I certainly notice the difference comin from Melbourne to Sydney. The roads over there are far better than the ones here.
In melb if there's a pothole for the first year or so they put a sign up saying "rough surface" and then they get off their arses and fix it properly. In syd it seems they just lift the whole block out and replace the block, not giving a rats arse if its level with the surface on either side (like on Parra Rd).
I travel Parramatta Rd every day from Silverwater Rd to Woodville Rd. I would take the M4 if there was a bloody entry/exit ramp for woodville rd but there isn't. That bloody railway crossing is a pain in the ass, bloody biggest road in Sydney and you have to stop every 10 minutes to let the train go past. Ridiculous!
There are 2 types of Major pavement types rigid and flexible and different usage concrete belongs to rigid, asphalt and bitumen belongs to flexible..depending on design
concrete povement uised in european countries(cannot be compared to Local Road)
-bloody expensive
-very durable, in fact almost no repairs needed for design life of 40yrs
-as far as I know, not in use in Australia, because population are too widespread and hence cheaper to actually fix the road at regular interval
Australian roads uses mainly asphalt and bitumen surfacing
asphalt are a mix of gravels, sand, bitumen..cost approximately 30 times (I think can't remmeber) to bitumen surfacing
on rural roads, bitumen surfacing are used..
-cheaper
-shorter lifespan
-as bitumen layer oxidises they loose their initial elastic charateristic and start to crack..water sips into base, layer and form potholes
- not suited fo high volume of vehicle turning
urban roads, asphalt
- longer lifespan
- has bitumen which acts as a waterproof layer before the asphalt surfacing applied
- simmilar concept, with time the bitumen gets brittle
-more adaptable for locations with high volume of vehicles turning
the Main Roads in W.A, not sure abt sydney usually leash out contracts for private companies to take care of the road... so in fact the stretch of road may not necesarily be under the goverment charge to mantain..Y.
usually potholes are fixed using this mixture called hotmix or sumthing..I can't remember...but it's basically another type of black goo stuff..to be shoved into potholes..
however if there are numerous of potholes, the whole road might have to be rehabilitated...
-remove initial surfacing layer..scraping...
-if base layer thickness are compacted by the yrs and vehicles passing through and are not within Austroad standard minimum requirement additionalbase layer need to be added
- and when that happed, compaction is required, and few more of test and techniques which
-after that surfacing the whole layer...before everythign done..
fixing a stretch of road is costly and take more than a day to be done...so usually roadworks are done during night time closing one lane at a time...and fixing that particular lane..
if that stretch of road is crutial, some serious traffic planning has to be done...if traffic is to be diverted on another road...the volume might exeed the design parameter of that particular road..and end up damaging that road..
this is a main road to syney so there'd be a high volume traffic so traffic disruption is less tolarable..I'm not sure how long the road has been in this condition, but there'll probably plans to restore the road...but will take sometime for approval and paperworks...
I was cruising up epping rd about 80km/h when I hit this fu_King great big pot hole that came out of no-where so hard that it felt like I hit a land mine or something. It was so hard that it shook the whole sunroof/light controls panel out of the ceiling!
You will DEFINITELY need a wheel alignment, and check that you didn't buckle your wheels.
Bummer :)
Straight down Parramatta Road to where the clock tower is, make a left and head towards Ashfield - WELCOME TO LAND MINE TERRITORY! :( Funny thing is that everytime I drive through there, I see more and more modified "
i was in my corolla didn't see it and BANG i hit it,it snapped my exhaust bracket,put a big crack in my windscreen which really SHITS me.
FIX THESE DAM ROADS YOU STUPID GOVERNMENT!
there that felt better.
Edited by eurospec
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
