only reason why i bought colover was so when im driving with the young lady i can see here boobs bounce
crap sydney roads are great if you ask me
only buy adjustable coilovers if
A) for boobies
B) for track work :lol:
everyone else is a wanker!!!
Edited by fatz
same here.. i refuse to pay tolls too! thats y i use parra road to get into the city..
yeah I used to use parra rd...4 times a week getting into UNSW for training but now I just use victoria rd/epping road and cross Anzac bridge. cuts the tolls out too!
As bad as the roads are (GTR with tein susp and f + r adjust camber) i cant get over the stupidity and lack of thought put into the organisation of roadwork crews.
If they have to block off 2 out of 3 lanes on a major road, why not start it at midnight? then finish before peak hour in the morning? (Obviously not practical when drying/curing is involved)
I travel very strange hours, and during the day when im out and about the road crews are digging holes and filling them in (not flat either more often than not), but the same road at 330am = empty?
Isnt it the RTA's job to ease jams? Not make them?
Goes to show the lack of care for the motorist from RTA.
Not sure where you're living, but can't say that happens around my neck of the woods.
Around here, road works start at around 20:00 - 21:00, and they're usually done by 02:00 - 03:00. I'd think that they should work through until 05:00, which will still give them time to clean up before the morning traffic comes in....and do a proper 8 hour shift.
Straight down Parramatta Road to where the clock tower is, make a left and head towards Ashfield - WELCOME TO LAND MINE TERRITORY! :P  Funny thing is that everytime I drive through there, I see more and more modified cars :D
Yeah this road is shocking! Frederick street! As I live near by I tend to use it a fair bit and my tein suspension really doesn't like it.
Do you use this road much Satanic? May have seen you around in the R34!
yeah I certainly notice the difference comin from Melbourne to Sydney. The roads over there are far better than the ones here.
In melb if there's a pothole for the first year or so they put a sign up saying "rough surface" and then they get off their arses and fix it properly. In syd it seems they just lift the whole block out and replace the block, not giving a rats arse if its level with the surface on either side (like on Parra Rd).
I travel Parramatta Rd every day from Silverwater Rd to Woodville Rd. I would take the M4 if there was a bloody entry/exit ramp for woodville rd but there isn't. That bloody railway crossing is a pain in the ass, bloody biggest road in Sydney and you have to stop every 10 minutes to let the train go past. Ridiculous!
There are 2 types of Major pavement types rigid and flexible and different usage concrete belongs to rigid, asphalt and bitumen belongs to flexible..depending on design
concrete povement uised in european countries(cannot be compared to Local Road)
-bloody expensive
-very durable, in fact almost no repairs needed for design life of 40yrs
-as far as I know, not in use in Australia, because population are too widespread and hence cheaper to actually fix the road at regular interval
Australian roads uses mainly asphalt and bitumen surfacing
asphalt are a mix of gravels, sand, bitumen..cost approximately 30 times (I think can't remmeber) to bitumen surfacing
on rural roads, bitumen surfacing are used..
-cheaper
-shorter lifespan
-as bitumen layer oxidises they loose their initial elastic charateristic and start to crack..water sips into base, layer and form potholes
- not suited fo high volume of vehicle turning
urban roads, asphalt
- longer lifespan
- has bitumen which acts as a waterproof layer before the asphalt surfacing applied
- simmilar concept, with time the bitumen gets brittle
-more adaptable for locations with high volume of vehicles turning
the Main Roads in W.A, not sure abt sydney usually leash out contracts for private companies to take care of the road... so in fact the stretch of road may not necesarily be under the goverment charge to mantain..Y.
usually potholes are fixed using this mixture called hotmix or sumthing..I can't remember...but it's basically another type of black goo stuff..to be shoved into potholes..
however if there are numerous of potholes, the whole road might have to be rehabilitated...
-remove initial surfacing layer..scraping...
-if base layer thickness are compacted by the yrs and vehicles passing through and are not within Austroad standard minimum requirement additionalbase layer need to be added
- and when that happed, compaction is required, and few more of test and techniques which
-after that surfacing the whole layer...before everythign done..
fixing a stretch of road is costly and take more than a day to be done...so usually roadworks are done during night time closing one lane at a time...and fixing that particular lane..
if that stretch of road is crutial, some serious traffic planning has to be done...if traffic is to be diverted on another road...the volume might exeed the design parameter of that particular road..and end up damaging that road..
this is a main road to syney so there'd be a high volume traffic so traffic disruption is less tolarable..I'm not sure how long the road has been in this condition, but there'll probably plans to restore the road...but will take sometime for approval and paperworks...
I was cruising up epping rd about 80km/h when I hit this fu_King great big pot hole that came out of no-where so hard that it felt like I hit a land mine or something. It was so hard that it shook the whole sunroof/light controls panel out of the ceiling!
You will DEFINITELY need a wheel alignment, and check that you didn't buckle your wheels.
Bummer :)
Straight down Parramatta Road to where the clock tower is, make a left and head towards Ashfield - WELCOME TO LAND MINE TERRITORY! :( Funny thing is that everytime I drive through there, I see more and more modified "
i was in my corolla didn't see it and BANG i hit it,it snapped my exhaust bracket,put a big crack in my windscreen which really SHITS me.
FIX THESE DAM ROADS YOU STUPID GOVERNMENT!
there that felt better.
Edited by eurospec
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
