hey all
looking at getting a r32. been in love with skylines for a while but not until a week or so ago i test drove a r33 gtst manual. I was expecting a lot but was kinda dissapointed. It didnt seem to have much go at all. I also didnt realise they weighed so much 1400 odd kg. not a commodore fan but i have one(vkwagon) unmodifed 308 auto with lsd .its crap but fast ,
my point is my $2500 commodore has raced kicked the shit out of r33 r32 wrxs and others .
i was so excited in getting a r32 but what do i have to do to make it move ?
cheers john
https://www.sau.com.au/forums/topic/97414-thinking-of-getting-a-skyline/
u know y? coz they were GTST. dont call skylines slow till u test drive a GTR. (no offense to any GTST owners.) but they r the true spirit of skyline.
kinda agree with u tho; had more grunt with a s15 than a GTST R33. dunno y.
as a matter of fact, GTRs r as heavy as the GTSTs, but RB26 makes the difference( they r completely different engines from RB25)
again, there r quick RB25s around; it will cost a bit money, and getting the power down is another issue when it goes over 350+hp on the rear wheels. Internally, Rb25s r not as strong either.
Rb20s r different; never done any work to it so i cant say anything. but the usual mods will increase the performance but dont know by how much.
S13 r great cars; personally i prefer the SR20 to the Rb20; they r light and have so much fun to drive; and after all, u can find mods designed for them easily.
my opinion any way. :)
Edited by frankxy
one thing i know for sure, Cold air intake(try a pod filter in a heat shield), a FMIC(be carefully with choosing the right one coz shitty ones will only increase the lag especially when u run the stock turbo), Wind the boost up to around 12psi which is safe enough, do the exhaust( dump pipe, hi-flow cat, and exhaust), u will get a significant power increase. usually u can tell the difference with the power of the car.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
