Yo, me again,
Been thinkin about BOV's - If I have a Steel exhaust turbine (new turbo), FMIC and 3" pipes all the way round the FMIC, do I really need a BOV ??
The turbo could hack it, and think of all that pressure I am venting when it could be going into the engine......
The noise is cool, but I could do without the attention .... plumbing back is another option...
Looking for your 0.2c
Cheers,
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/
Silver, thanks dude !! 14 PSI low, 18 PSI high - but it's not the BOV that I'm worried about - it's the turbo....The BOV is a Turbosmart Supersonic, so it can handle it.... Just wondering if I really need it...... Turbo life, etc.....
Cheers,
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-149547
Brendanf - have you ever heard what it sounds like when the pressure from you pipesand coola is reversed and hits the compressor wheel? pft, pft pft, pft - It doesnt sound pretty.
The plumback could be an option, but I think any BOV if fitted and adjusted properly is a worthwhile thing to have as they stop the back pressure slowing down the urbo on gear change - once slowed they have to speed back up again = lag. Sure the lag wont be as bad if you are going hard, ie less time between shut/open throttle valve and because you have the foot to the floor, but that air must go somewhere and that is straight back through the turbo the wrong way.
I probably need to duck for cover here, as I know that there are a few lads out there that seem to think that a BOV is a complete waste of time and money, but, as requested,
This is just my 0.02
Steve
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-149554
Steve, thanks man - no I haven't heard that - But I can imagine the stress.. Which is why I asked the question ...... It really comes down to physics - I know the BOV is the safe option - And I don't wnat to open up a shit fight - I'm looking for ppls opinions and experiences, so I can make a decision.
Right now, I am gonna plumb the BOV back to the air filter - but if there is a compelling reason to do without it altogether, I'll listen to that too !
CHeers,
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-149573
Brendan,
have a chat to Merli, He fitted the Trust Type R, one of the best BOVS on the market for heavy duty applications such as yours.
If you need one pm me as we have to in stock at UAS that are available at a very good price for you
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-149933
Considering all of the back pressure forcing your Turbo to spin the wrong way, my opinion is that a BOV is essential. And considering what you've just done to your engine, I would imagine the last thing you'de want is shortened turbo life. For a BOV to be cleared legally, you do need it plumbed back into your intake.
If you plumb it back into your intake, then you're not going to be wasting it at all :)
As it is on my car from the factory (albeit an MR2), my BOV is plumbed back into the intake pipe between the AFM and turbo inlet.
My $0.02 and happy decision making
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-149965
Hey Brendan...
Okay, your theory here is quite flawed. All that air that's being vented wouldn't be going into the engine, because the BOV should only open when you've shut your throttle body, and not letting any more air into the engine anyway!!!
Does that makes sense? Basically your BOV should just be lying dormant until such time that you take your foot off the accelerator. Your throttle body shuts, but your turbo is still spinning VERY quickly and trying to force air past your now shut throttle body. Where can that air go?
Well if you had a BOV, it would vent to atmosphere, or with a plumbback, it would be returned into your intake manifold, before your turbo which means air will flow back through the turbo in the right direction.
If you didn't have a BOV, where would all that rushing, pressurised air go? It ain't going into your engine as you think, because the throttle body ain't letting any air enter... It's going to have to STOP, turn around and travel back through all your piping, back through the intercooler, and try and force it's way back through the turbo, causing what's called "REVERSION" of the turbo blades... This wall of compressed air going backwards hits the turbo blades like a shockwave, and is NOT good for the life of the turbo.
When I bought my car, it didn't have a BOV on it, and I quickly threw on a Blitz Dual Drive that I had... It wasn't big enough for my application, and it caused my car to run like crap... The spring wasn't strong enough and it wasn't completely shutting and leaking air... So I got rid of it, and put a Trust Type-R on there, as BY BY said, and the car runs PERFECTLY. Even though it vents to atmosphere, the Type-R has a super strong spring that shuts the BOV TIGHT, and doesn't allow any air leak, even at high boost pressures.
With your car, I'd probably suggest the same BOV.
Hope that helps dude.
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-149967
Thanks guys,
Yeah, I thought as much - And you are spot on Merli - I realised after posting that the air isn't going into the engine, it's being pressurised between the turbo and the throttlebody butterfly. I was told (prolly unreliably) that with a FMIC and steel zorst turbine that even with the pressure, it should be OK , and when you go to open throttle again, you have boost imediately (rather than having no pressure between TB & Turbo and boost would need to spool up again.
I may just plumb the Turbosmart Supersonic back in (ATM vents to atmosphere and makes a filthy sound) - I'll talk to you guys about the trust jobby tonight...
No BOV is def. bad idea.....
Thanks fellas,
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-151040
About blow off valves opening under boost, that shouldnt be happening if the thing is on good order.
On one side of the diaphragm you have the compressed air from the turbo, the other side you have air from the inlet manifold. So under boost both sides of the diaphragm see the same pressure (Note: about the same pressure as your BOV is usually mounted close to the throttle body so only place for possible pressure drop is the throttle body itself)
so with combination of spring trying to resist being compressed, as well as both sides of the diaphragm seeing the same pressure, it should remain sealed and not leak boost.
Now when you back off the loud pedal and the throttle body is closed, the compressed air from the turbo is now increasing as it is attempting to pressurise a fixed volume, also the inlet manifold is now in vacuum.
So the diaphragm of the BOV now has increasing pressure on one side and vacuum on the other, so resulting in the valve opening. This vacuum and pressure from the inlet manifold is the reason you dont need stiff springs, as the pressures are acting as a means of sealing/opening the valve.
So there are plenty of BOVs due to their age and quality, that leak. This has mostly to do with the quality of the seats (or the internal surface of the valve that meets when closed)
On any turbo car i think they are a good idea, in fact necessary. In addition to the reasons mentioned above there is also a fluid property of air called Adiabatic combustion, meaning that when it is compressed it heats up. So by making the turbo further pressurise the air in front of your closed throttle body, you are further increasing the temperature of the air. By venting it to atmosphere you avoid this, as well as plumbing it back to behind the filter to be compressed and coled again.
Now if only someone can tell me the type of BOV being used by the yellow S14 on Best Motoring 6, im off to buy one. It sounds great. For that matter so doues the White Amuse Supra in Best Motoring 5.
https://www.sau.com.au/forums/topic/9750-bov-do-i-need-one/#findComment-151673
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
