I’m selling the following parts for a friend who was doing up a skyline but has run into finical problems and needs to sell the following:
(These parts are no more then 500km old)
Trust intercooler + pipes $1500 (GTST)
Trust White face boost gauge $200
Nismo 555cc injectors (side feed x 6)
Bosch fuel pump
The car is also for sale
Black ’96 Gts-T,
New Advan 3L engine (with trust pistons, less then 1000km and all paper work)
Lowered king springs
Trust exhaust
Trust pod filter
Red racing seats
Full body kit
This car is in a one condition
$23000
For more details you can email me [email protected]
https://www.sau.com.au/forums/topic/9756-skyline-parts-looking-for-new-home/
Guys I don't wont to be rude but PLEASE read the above info before emailing me and asking what size the injectors are.
Zila33: yes sorry man they are side feed injectors, and there are 6 of them
Pawley: Yes $150, but for you $160 :P
Nismo99: Side feed injectors, and there are 6 of them. $350 but for you $360 :D
Thats a huge bargain on the injectors. Six for the price of one.
Da-man any ideas on what seats are in this car? are the Recaros or generic sport seats?
Cheers
Nick
Da Man, mechanical or electronic boost gauge? It is electric if it just says 'turbo' on the face, but if it says 'trust super tuning systems...' on the face it is mechanical. Let me know.
Guys the gauge is LIKE this temp on (but it is boost). with inregards to the cooler exact dimensions i'm not sure but its may bigger then the standard one, and usually requires some modifing of your front bar, I will get exact dimensions durring the weekend.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
