It's not the same as lightening the flywheel.  The flywheel gives the engine end of the drive train additional momentum, which assists with maintaining revs (helps you to not stall) when you let the clutch out.  This improves driveability.  There are some other benefits during gear changes.
A lighter driveshaft (or lighter wheels) will not have this effect on driveablility, as they are on the other side of the clutch.  There is no downside - beside the cost.  :rolleyes:
I don't understand your logic. The tailshaft is a rotating piece of the drivetrain, exactly like the flywheel.
I'd argue that there is a lot more bang for buck in things with large diameter because inertia does after all have a r^2 component.
I'd pick flywheel lightening to be biggest bang for buck for reasons of weight, angular velocity range and diameter.
The rest would be hard to separate. Wheels get the vote for weight and diameter but you want the weight removed from the extremities, which may be difficult to achieve.
Tailshaft is relatively skinny so i'd think it's bang for buck is pretty low.
  • Replies 119
Posted Images
the down side of a lightened flywheel is that engine revs will drop quicker when gear changing, because there is less energy to keep the momentum going
what hes saying is that the tailshaft is disconnected from the engine when the clutch is in on gear change, so you dont get this affect
the car itself may lose momentum quicker(although would probably be marginal), but the engine revs wouldnt be affected
Right on.
I agree that the flywheel will offer greater performance benefit from an inertia perspective (hence, I have one in my track car). However, you do pay for it with driveability. The driveshaft offers less bang for buck, but if I had an infinite supply of loot, I'd buy one. :)
Another benefit to a lighter flywheel is that it spins faster than the driveshaft in the gears lower than 4th. As such, it needs to accelerate faster and therefore offers further potential gains from lightening. The driveshaft spins faster than the wheels, but with 4 wheels there is a greater opportunity for weight saving.
Edited by clayoth
As you can see, they aren't actually made by Trust: http://www.trust-power.com/14import/carboneshaft.html
There was one for sale on Yahoo JP a few weeks ago (brand new I think). Unfortunately it was for an R34 (IIRC), otherwise I would have been sorely tempted.
im not a big fan of nismo i havent had the best of advice from them
Ummmmm.. are you talking about www.nismo.com.au, or Nissan Motorsport (aka. Nismo)? BIG difference.
only reason the GTR ones are $4000 is because it has GTR written on it
you know what i mean
all i want is a place that sells these shafts not snide remarks leave that for the SDU forum
I'd say it would the carbon fiber that costs the money, not those three letters.
vivid racing might be able to help. $US + Shipping, though.
face it. this is an expensive way to go faster. why not just get a shorter diff?
eh - and the snide comments are free.
why not get it directly from
http://www.acpt.com/
I think it will only cost around $AUD1500
may be someone should organise a group buy for these badboy. There are also some safety benefit with cf driveshaft. However I've never heard of gtr driveshaft breakage.
Engine revs change during gearchanges anyway tho, so I still can't see the downside of having a lightened flywheel.
If you are going to use this argument then you would also have to say that weight savings anywhere on the drivetrain side (or anywhere else in the car) will have a negative effect during gear changes. ie car will slow down more quickly.
Edited by browny
iwells i was talking about www.nismo.com.au
ebola thoes three letters cost in this case $3500 more for a simlar product
thanks for your help guys i will have to inquire the places in the above mentioned and see what happens if you have any other sites let me know
I see there are a few people commenting who actually don't have any experience with either a lightweight flywheel or tail shaft.
Neither the lightweight flywheel nor the tail shaft cause drivabillity issues.
Thats from experience.
Keep thinking about it. and then ask someone who builds race cars.
I have just got info back from Jame Martin the product manager at ACPT.
They have off the shelf designs for R33, R33 & R34 GTR tail shafts. The price including shipping to Australia is $2,160 Aussie dollars for just one, I am sure we can get it a tad cheaper again if we group buy.
This makes it half the price of the jap units and more than attractive enough as a modification when you consider that there aren't too many mods for $2k that are as good as the accelleration you are going to pick up from one of these bad boys.
I shouldn't go on but the mines R34 is equiped with carbon tail shaft and it is quite a big reason behind the 'response' of the car.
Here is one test of a rotational mass reduction on a V8 setup, the big thing to note is the massive reduction in time taken to achieve both maximum horsepower and torque once weight is taken out, that boys is accelleration increases. Note this is taken in 4th gear under load.
http://www.vetteweb.com/tech/0407vet_flywheel/
Group buy anyone ? :P
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
