i imported the car in dec last year...left it sitting the the garage, until sept this year...just kept adding stuff to it and now it's costed me way too much money...i havent even really driven it at all...but i need some money to live...
1989 model
88000km metalic gunmetal paint
ENGINE::
RB26DETT
N1 turbos
Nismo 550cc injectors
Nismo fuel pump
Fidenza (u.s.a made) adjustable cam gears
ARC fmic
Xtreme semi puck hd clutch
X-force stainless 3" cat
2.5"x2 into 3.5" GTR front pipes
Fujitsubo Power Getter catback exhaust
Apexi power intake pods
2x HKS ssqv
Clutch slave cylinder
Clutch master cylinder
SUSPENSION/BRAKES::
HKS hypermax II coilovers
Tein caster rods
Cusco rear camber arms
Cusco rear caster arms
Cusco rear toe arms
braided brake lines
GTR front brakes (5stud)
Cusco 2 way LSD
Cusco front strut brace
R33 GTST rear brakes (5stud)
INTERIOR::
Apexi power fc + controller
Apexi RSM (blue screen)
Apexi pen type tt
Omori boost gauge
Omori oil press gauge
Omori water temp gauge
Omori oil temp gauge
Defi D-gauge 4.5" shift light tacho
Veilside Gear knob
Pioneer CD deck 2000 top model
EXTERIOR::
AVS Model 6 Rims (17x9.5 +18mm)
Enkei light weight 3 pc rims (17x9 +30mm)
92 Model front bar
93 180sx front lip
R32 GTR wheels
Flared guards front and rear
N1 head lights
late model tail lights
it's costed me about 30k up till now...and that's way too much for a 15 yo car...
i dont think i'd be able to get much more than 15k for it, but let me know what you guys think, any advice is welcomed
https://www.sau.com.au/forums/topic/97694-thinking-of-selling-out/
Its only worth what someone is willing to spend on it. If early 20s kids hafe 30g to spend then its worth that.
but unfortunatly they dont. so you should get 20g for it. considerng all the goodies.
I've spent almost that much on mine too... But then I have done 65000kms on mine too.
I'll do ya a deal. You paint it bright red, I'll swap ya for a nice economical 2l cefiro :). Only condition is, I keep my wheels.
I think everyone goes thru this phase at some point of ownership of a performance vehicle. I did it twice when i owned my R33 but eventually sold in for financial reasons, only to spend more on the next car, Satria GTi. Then sold that due to $$$$ and bought a $3,500 A-B Nissan Pulsar.
Only to 6 mths later buy the Cefiro. Due to unforseen costs on the Ceffie I to have looked into selling it, but i think u just need to sit down and do your sums and see if u really are going to get ur monies worth.
I think the biggest question u need to ask yourself is...
"Am i going to stick with a cheaper, economical car, or am I just going to get another performance vehicle 6 mths later??"
I did this twice over and if i knew it i would of just kept my original R33 instead of waisting thousands of $$$$$ selling, buying, moding, etc...
My rant / 2c
Ando
i know im gonna get another performance nissan...i dont qustion it...not even for a second...after all...it's happened with my last 6 car...could have a house by now (so the parents keep telling me :) ) mostly likely get an r34 after this...might call it quits for a while after i get that...but then again...that's what i said last 6 times too :) something abt turbo nissans...it's better than drugs :D
:( something abt turbo nissans...it's better than drugs :(
Damn straight.
I went from a N/A subarooo awd to the ceffie, my first RWD car not to mention ridiculously overpowered for a novice povo like myself but I never looked back not even after the several near crash experiences in the first week of ownership (it was raining all week, drift cars and rain = fun, unless your completely new to the RWD oversteer thing then its F***ing scary :P)
Since the ceffie I have driven loads of hi powered cars, and the consensus is, high boosted nissans f***ing rock
and we are all on these forums coz we have the same problem with car related addictions :D
Edited by BasketCase
Bugger that!
If I were you, I would sell the parts on their own, here or on eBay, then just sell
the car for what it is. You don't really get the money for the parts if you sell them
with the car, but on their own you should do really well. :)
That's my bit, anyway...
Good luck with the sale either way.
Adrian.
i had the idea of pulling the engine out and selling as a complete rwd conversion package, with all turbos, injectors pfc, gbox etc and put in that s15 motor i got sitting in the garage...but that means more time off the road..and engineering...
f**k...i'd be happy if i get 18 for the car minus some stuff from the list...
dave...i thought about that idea..but then i dont wanna deal with smart ass little kids on the forums talking shit, you know how these c**ts are in the forsale sections...
Dude, for $7k extra Id learn to put up with some 16yo smart arseness. $7k is a nice reiable run about including fuel for a year.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
