I just imported a hot as R32 GTSt with heaps of mods but it came with a poxy poverty pack steering wheel. I'm after a R32 wheel in any condition. (peeling a bit is ok. As long as it's not falling apart.)
I don't really want an aftermarket one because I love the size and feel of the R32 wheels. I had one on my last car.
I would love a GTR wheel but a decent GTSt one would be better than what I have now.
Price will depend on condition and if it is GTR or GTSt.
PM me or post here if you're selling!
thanks,
Russell
I have an r32 GTR steering wheel in very good condition for 180
Can you please send me a photo of the wheel to [email protected] and [email protected]
not sure which one I'll check first.
Or post it on this thread. whatever suits you. Where are you located?
thanks,
Russell
have 3 syd buyers only
I'm in Melbourne but if you change your mind and will post... let me know.
GTR or GTSt?
Russell
How much will you sell the best conditioned one you have i am VERY interested because my GTR came with a Nardi "Deep Corn" wheel (im not a fan of it) and if so could you send me pics of all 3 steering wheels, to.. [email protected]
Cheers,
Michael K.
Cheers,
Michael K.
Are you going to be selling the Nardi wheel?
How much would you sell the Nardi wheel for with boss kit?
Russell
Russell
Yes i am selling the Nardi wheel but i want to buy a GTR Wheel first, otherwise i wont be able to drive around :D .. but a friend of mine offered me $250, if you can beat that then it's yours.
It is rapped in leather and has red stitching and is 350mm in diameter in very good condition, i'll put up a picture of it when i get the time.
Cheers,
Michael K.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
