can u make a r32 gtr skyline 100% rear wheel drive but still have 4wd at a flick of a botton i no u can pull a fuse or somthin out and make it like 80% rear wheel but just wanna no if this can be done and for how much u think and would u be able to still have it as a every day driver
Edited by overboost
https://www.sau.com.au/forums/topic/97961-r32-gtr/
Send a PM to 'Duncan' and see if he has more ATTESSA controllers for sale.
And if you're after help, cut the sms talk dude. There is no saving in typing 'no' instead of 'know'. It just makes it hard to read and pisses people off. Also try breaking your post up into bite size chunks commonly known as sentences. Cheers.
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1779132
pulling the fuse makes it 100% rear wheel drive until you refit the fuse.
you can make your car 2wd while driving along in 4wd. step 1, put your foot on the clutch while driving, step 2, turn the ignition off while your foots still on the clutch, step 3, turn ignition back on and foot off the clutch, now you will be in 2wd without having to pull the fuse out. to ensure your in 2wd the orange 4wd light will be lit on the dash. please note that this is only possible on the R32 GTR's. the car will automatically go back into 4wd mode when you bring the car to a complete stop.
hope some of you lucky GTR owners have learnt something new, happy sliding... B)
Edited by gtrgodzilla
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1779600
You can get a torque splitter than will do the job as well.
Dude refer post #2. That's what an ATTESSA controller is.
Overboost, yep, they can adjust it to your liking, from max split to no split. The search engine will turn up all the answers. :)
Heath I hope you've been behaving yourself mate! :) hehehe :blink:
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1780266
The ATTESSA system in the R32 GTR is pretty good for its torque-split-ness. I notice it only kicks in (that is, the front torque guage shows a reading) when I launch hard from a standing stop or I go over slight bump on the freeway etc.
It will never have more than 50% of the drive at the front wheels anyway and to get that you wouldn't have time to notice what the guage is reading as you adjust the awesome slide you are in :)
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1783190
Just for those that aren't aware, the torque split gauge does not measure a percentage, it measures kilogram.metres, ie torque.
A reading of 50 on the gauge does not mean you're driving an overweight STi :D
That said, when your GTR rolled out of the factory years ago with its claimed 353Nm. That's around 36kgm, so a stock car won't see 50
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1784364
Yeah, happy sliding for me too yesterday then a bit of a drift around the corner, then the backend broke loose and more oversteer, then I put a bit more throttle in to get the front torque to pull me straight but...
Round I went 180 degrees, parallel crashing into the 30cm high kerb on the other side of the road.
Damn it sucks crashing and f*#king up your wheels, suspension arms front lip and spoiler, and throw in a front crossmember and cv joint too. Only happened yesterday arvo Just out of lithgow heading back to sydney.
My fault, going too quick around a corner.
Take it easy guys.
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1784425
Damn Sean! I saw your car for the first time last week too! Well as long as you're alright mate.
I had a 'moment' coming down Hawkesbury Rd a fortnight ago on a Friday morning when the road was greasy. I was trying to suss out how the torque split works and I did a similar thing but *just* retained control (it was a 35kmh left into a 25kmh right I think). Learned a good lesson! No damage, never connected with anything but enough to speed up the ticker for a few k's.
If you're after parts, let me know, cause I bought a stack (bumper etc) when I had my car painted and have a fair idea of how much Nissan can sell them for.
Mark
https://www.sau.com.au/forums/topic/97961-r32-gtr/#findComment-1788062
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
