as the topic states will gtr standard cams and cam gears fit onto a rb20det, cause i have seen a few cars around on for sale sections saying they have them fitted on, i wanna konw if thats just crap talk or if it is really done, and also what difference is makes, is it minor or does it do some good?
thanks for your time
shaun
https://www.sau.com.au/forums/topic/98064-standard-gtr-cams-and-cam-gear/
Hi Shaun
Dude I have an RB26 not RB20, so this is just what I've read on SAU and HPI etc. The cams will fit but apparently they aren't terribly good on an RB20 and the dynoed car actually produced less power than with the stock cams. Someone smarter than me will know why.
Not sure about the cam gears and I really wish I could find that thread/article. Might have been the HPI article where they 'made' an RB24...?
Cheers
Mark
Been plenty of threads on here about fitting them. Has been done, run a search.
I say why though.
Get a profile that suits your engine and required outcome.
If you are planning on just wacking them in and gaining a worthwhile performance improvement you would be wrong.
If you put in the GTR cams, you also have to run all the GTR lifters and swap all the valve springs as well.
Like RB30 said....better off getting another cam that suits your engine. The GTR cams are a solid cam, whereas the GTST cams are hydraulic.
The GTR cams have a 9mm (?) lift and the GTST ones have 8.5mm
It would cost you a fortune to put in the GTR cams....picture the cost of doing a head gasket.....plus the cost of the cams, lifters, and springs. $2000 I reckon. You will get better results from bolting in a set of Tomei Pon cams and they are only $800 delivered.
ok you are a long way off base mate. plenty of people have installed GTR cams into RB20 without haveing to replace the whole valve train. also can you tell me why you'd need to change the headgasket to install cams? solid cam vs hydraulic cam? no such thing mate. perhaps you are talking about hydraulic lifters. now i am no RB20 expert but i am about 90% sure they have solid lifters (like an rb26) not hydraulic.
Well, I'm sorry that you are wrong. The RB20 lifters are hydraulic. The GTR ones are solid shimmable buckets. And you DO have to remove the head to change it over properly because you need to remove the valves and springs to change them over as well. The GTR cams have a much greater lift and will f**k the Rb20 valve springs. And BTW, there is such thing as hydraulic cam and solid cam. If you've ever done ANY engine building in your time you would know that.
well there are no 'hydraulic cams' in any RB engine. RB25s have hyrdraulic lifters and as such have a cam to suit, but other than being different specs (mainly lower lift, shorter duration and different base circle) the cams are not hydraulic themselves. like i said above i still think you are talking about the lifter mechanisms being hydraulic.
as for RB20s having hydraulic lifters, i do stand corrected then. i have never had an RB20 head appart so i wasn't sure. thanks for clearing that up for me :)
with the cam swap there have been a number of people who have done it here and none of them that i know of have had to change the valves, or the springs, or anything to do with the valvetrain other than the cams. some have had sucess with the swap, some have had problems. I do agree that it may not be worth it, though if you are on a tight budget you can get some GTR cams for about $200 and that's about all you need vs bolt in jap cams at $800. the jap cams will no doubt give a better result though, but cost 4 times as much.
I am not referring to the cam being physically hydraulic. A hydraulic cam is used to refer to the fact it follows hydraulic lifters. You cannot use a hydraulic cam on solid lifters or vice versa. The solid GTR cam must be used in conjunction with the solid GTR lifters. The valve springs don't absolutely have to be changed but you will suffer valve bounce from around 6500rpm because the rb20 springs are not designed for a 9mm lift. Sure you can bolt them in...but you are stupid if you do. It would be like saying....I can only afford 4 forged pistons so I'm gonna run 4 forged and 2 cast. You can still do it but you will suffer in the long run.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
