Who was it?
Who were the people who laid it all down on the line traveling where our street directories were of no use?
Who was the person who passed a message onto the waiter?
WHO WERE THE PEOPLE WHO OWNED TNS?????
It was us!!!!!!!!!!!!!!!!!!!!
Me and Frank!!!!!!!
plus our buddy Ric!
we had to send someone in who no one knew so you wouldnt have a clue what hit you
or your exhausts for that matter :P;)
Here is pictures from our wonder full yet scary trip up north!!!
http://boredofstudies.org/mark/tws/
OWNED!!!!!!
https://www.sau.com.au/forums/topic/9822-the-answer-every-body-wants-to-know/
  • Replies 141
ok in an early interveiw with TOSH, i scrambled some info on how the camp is still recovering from that fateful night.....
i wanted to get in quickly while the pot was still boiling and TNS are still scratching their heads in disbelief
here goes:
UR2EZ (8:46 AM) :
ok your thoughts and emotions :P
TaKaHaShIRyOsUkE (8:46 AM) :
1 thought: thank ****en god my car wasnt there :P
TaKaHaShIRyOsUkE (8:53 AM) :
"OH MY ****ING GOD. I CANNOT BELIEVE THIS"
UR2EZ (8:56 AM) :
BAHAHHAA so who took the slip
TaKaHaShIRyOsUkE (8:57 AM) :
Duncan
TaKaHaShIRyOsUkE (8:58 AM) :
he's just gone "you're joking!"
I saw Andrew glance at it and just go. "oh shit!!!!!"
TaKaHaShIRyOsUkE (8:54 AM) :
words really can't explain how I felt when I saw it. hahahahahahahahahahah that it the best I've evr seen
We even messed up TNS so bad they turned on their own...
TaKaHaShIRyOsUkE (8:52 AM) :
and all the guys were convinced that I was an insider who knew about it all along
They had no idea who it was, EXECUTION AND TIMING WERE PERFECT
TaKaHaShIRyOsUkE (8:50 AM) :
I was convinced it was Loz
Well this just inforces the fact that WESTSIDE IS DA BEST....
and to end the interview tosh had one last thing to say
man I still can't believe it
And at ^^^^ that moment we at TWS feel complete
We knew TNS would never be the same after sustaining such a blow as that....
signing out
TWS
Originally posted by jtir
ROFL
The exhaust even got fisted!!!!
YUP no holding back....
was a first for me aswell....
also after all that GIVING i need to TAKE aswell...
that four door line' gave me some good lubbin....
not as good as TWS lub... but hell any lub will do....
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
