  • Replies 141
Knat, thanks. It's a Sony DSC-S75. About $1300 retail nowadays I'd guess. No special filters or anything like that. AFAIK, none are actually available for that camera. The effects you're seeing are the result of massaging aperture and shutter speed settings (not sure if you know what that means, but basically a decent digi cam with good manual settings options will allow you to get such results).
RONIN - Ok mate. I'll have to email it to you tonight though. Send me a PM tonight with your email addy in it. :)
Tex
Originally posted by Moanie
Hmmm...i dunno....I'll try and make it to the next one....but if my car gets owned, there will be trouble! :)
Moanie, fear not, Brendanf and his incredible light sabre will defend you :D
OMG!!!!! i just found this thread BBBBWWWAAAHHHH!!!!!
yes... welcome to last century helen.....
urmm... this was soome MUTHDA FOOOKEN FUNNI SHEIT .....
5 months ago, i was introduced to the term 'OWNED' and then, 'OWNAGE' and now...... the things u learn everyday thereafter!!
nowz.... someone's gotta say this... you little broTHDAs out there.. need to urmmm.... get out a bit more... i mean stay home a water the gardens a bit more ... PWAAHH!!!!!!
good work.
hahah nice OWNAGE by TWS.. i just found the thread too.. i was off for 2 weeks up to forster.. where i met a bunch of other guys with skylines out on a night of runs (they actually run down the main street in forster.. one of the guys said they dont have good long straight flat smooth roads around where it's good to run..) but none of them heard bout SAU.. or TWS.. so i intro'd them to it... a fresh bunch of virgin zorts up there too =)
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
