  • Replies 141
Originally posted by Dr_Drift
lowlux... you got all ya bits back??
He's got his ECU and CAS :D
dunno about his cam's though.
Originally posted by INASNT
r they full slicks or semi?? i want dibs on those so i can run a low 13!! :D
They are semi's.
Advan's i think
doc, do you think my mate can put his Twin Turbo Supra up for a dyno and a tune? he's keen and will confirm if you'll let him run.
Oh and when I meet ya on the day, can you bring the glovebox cover and the gearknob that I wanted off that R32 wreck you had? Thanks!
Gerald, you comin on the day as well? Dox told me u had brakes n rotors available... can we work sumfin out, coz I need a service done on my car as well.
Sorry guys they're not actually my tyres, and the owner has requested them back..... :(
If anyone who has not confirmed wants to come along and see if we can fit them in they are more than welcome... no guarantees though...
Doc.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
