I'm selling my R32 Nismo Edition GTR and I recieved this hilarious email from some "expert" on eBay of all places, thought I'd share it's a good laugh:
"Sorry mate but you may want to research a bit more before you claim something. Nismo never, ever, built factory r32s. In fact the first GTRs they ever released were R34s(10 of i think) which was not too long ago. They bought second hand r34's and did them up. I'm sorry but a previous owner in japan may have added all nismo items(V-SpecII N1) to the car but they were never released by nismo themselves. V-SpecII N1 models made by nissan used some nismo parts, but yours is not one of those. It doesn't even have brembos or V-Spec wheels. Sorry your number on the firewall does not mean 219 out of 400 either, that is part of your VIN/chassis number. Terribly sorry to disapoint you. Hey at least you didn't try and claim that it is 1 of the 100 australian delivered r32's as i actually own one of those. Good ploy though for trying to sell it. cheers"
My reply:
"You've got NO IDEA what you're on about mate.. quite amusing as you seem to think you're some kind of knowledgeable person. Do you mind if I copy your message and post it in my local club forum? The other members will get a kick out of that.
I especially like the bit about the number on my firewall, you've got no idea what you're talking about... hilarious.
Cheers for the good laugh."
Goodstuff...
https://www.sau.com.au/forums/topic/98323-nismo-edition-r32-gtrs/
this does not make any sense because he totally contradicts himself, first he claims the first gtr's were the r34's and then he goes onto say he owns an australian delivered r32, (unless he's so stupid he doesn't realise 'his' r32 is a gtr) funny though, thanks for posting it!
your tyring to sell a 1990 GTR as a 1991? with genuine 37K? how do you know they are genuine? cause the person that sold it to you said so... hmm $33K for what is a pretty standard 32 GTR. also can you tell me how you fitted your master cylinder inside the clutch? that is a pretty neat trick, if you can show me how it will save me some space in the engine bay. although i guess your car must be pretty special as it has more than 1 timing belt and 'front end' bearings?
Glad you're all getting a kick out of this guy..
It was a private "PM" in eBay so there's no public thread, unfortunatly.
His eBay name is "silvergho5t" anyone keen enough could contact him on ebay but he hasn't replied.. It's possible he has actually done some homework.
Relax dude, so I made a typo re: the "master" cylinder and timing "belt" geez...
I'm relaxed i'm just not a huge bullshit fan. c'mon mate, a car you bought for <$20K is now worth $33K? and please, genuine 37Kms... i just find that it's a bit rich to claim them as genuine without any proof. by all means claim it has 37Kms, but saying they are genuine to me implies you have some proof. also how did you comply a 1991 model under the 15yo rule?
First you're trying to tell me how much I paid for my car (<$20K?!?!?)
How do YOU even pretend to know how much I paid for MY car? Maybe you're a mind reader? And I dont give a rats what you find to be "a bit rich". Believe what you want, I have proof for any genuine buyer who looks at the car.
How come you're asking me how I complied a 1991 model under the 15 year rule? I thought you knew everything about my car?!?! Why don't you tell me how I complied it, maybe you also tell me how much that cost me?
What else can YOU tell me about MY car? This thread keeps getting funnier and funnier!! :D
Seriously but mate, mind your own business and go post in a forum that you may be able to help someone in. That's what these forums are for.
Edited by ScottKing GTS-4
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
