hey guys
after boosting my car with a dodgy inaccurate boost gauge...
im left with very little or no boost, depending on the rev rannge.
the BOV (it's plumback) doesnt let off a loud high pitched PSHIII anymore
the car will barely hit 80km in 2nd gear, takes ages to get there too, SLOW!
im also left with car running way too rich and staling...
Have any of you experienced this?? is it my turbo?? would these probs be a sign of it being blown/dead???
i live too far away from a decent mechanic, so your help would be much appreciated!
cheers
https://www.sau.com.au/forums/topic/98473-whats-the-symptoms-of-a-blown-turbo/
what does the stock guage show?
does it go beyond 0mmhg as in the dead middle
blown turbo symptoms:
pop noise when it happens
maye some smoke (oil seal gone)
whinning or "bearing scream" from the turbo
if its making some boost (ie above 0 then its fine) it its most likely you are running too much pressure, the ecu has protection for excess airflow which is commonly known as boost cut. turn the boost down a little and try again
Hey paul
just took for a run then... it goes above 0 and maxes at the first line
still my car feels like a slug. whne i drive it... its almost as if the boost stops, like theres an empty spot. and when you change gear the boost come back only momenterly, sometimes if i keep tapping the peddal, the car goes quicker than if i were to hold it down.
would it have anythign to do with the wastegate acctuator. coz from what you said, the turbo works,,, but it works strange as in duration and timing???
as you can tell i dont know lot about my car?? and no one around here does either
thanks for the reply!
Edited by hijaked
hmmm. ive curently got s silvia ca18t with the same problem:
0.3bar boost with the actuator line puled off!!!! :blink:
no leaks any where
straight of the dump pipe(no exhaust/unbolted)
turbo spins easily and has minimal shaft play
i really couldent be f**ked pulling the turbo off.
its got me stumped
Yeah.. could be if it hesitates it's R&Ring as it's detecting too much airflow, yet when you use 3/4 throttle and keep it a bit lower it'll be fine..
had this happen to me when I was running about 0.7/0.8Bar as it would detect too much airflow, engine would "hesitate" - yet as soon as I put it back down - it was all good..
have you tried winding down the boost a bit and see how it goes..
hey guys...
ive got one of those turbo tech thingys... altho when i first boosted it, it was with a turbosmart one...
yea i mean the line thats in between the +7 and 0... ill turn it down as soon as i get to my car, and see how it goes. hmm what is the minimum psi you can set it?? can it be lower than 4???
its just got me stumped... coz theres lot of people boosting their stock cars and have no trouble, one dude i know with an r33 has his on 10psi stock car... with a pod filter.... and a atmo bov... hes car is running fine, a lot better than mine!!!!
Edited by hijaked
* R31Nismoid
what do you mean cooler piping??? leak or blockage???
if its dirty or what ever.. whats a good way to clean it?? possible to clean the cooler?? i have a un named fmic
sorry to be off topic... but whats a good way to clean the afm... im sure one of you blokes would know
hey guys.
i turned the boost down so that the stock boost gauge would max out about 1 mm below the line between 0 and +7.. the car felt a little bit punchier, yet still runs like garbage.
* R31Nismoid what parts of the car should i check??
would the fact that my car is running 'really rich' affect my car?
the cars not bad up untill you get to 70kmph..... then it just feels like a landcruiser powered by a lawn mower...
as i said before... im from the sticks, no mechanic round here would know what do to with the rb. so i do appreciate anythign said! thanks R31
Edited by hijaked
keep turning the boost down until you get the response you expect.
you are basically working around the stock ecu's excess airflow protection. it will run mega rich and dump the timing when it picks up too much airflow. so keep turning the boost down bit by bit until it feels normal again.
hey guys.
If you've turned down the boost... and its still doing it.
Its leaky cooler piping which is getting a strong suggestion.
I cant tell you where. Thats for you to workout.
Go alone ALL the piping/hosing and triple check all the connections to make sure they are tight.
I cant offer anything more than the piping... if you dont know where it is... time to take a drive to a mechanic. Regardless of where you live
the other thing you can check is see if the wastegate actuator is still attached to the wastegate arm thingy.
My g/f's 32 had a similar problem... boosted, then nothing, no more boost, no more whoosh, no power, and a louder exhaust.
At first I thought it was the exhaust wheel had disintegrated. But Burko on these forums had a look, and was in the process of changing her turbo over to my old turbo when, after he removed the turbo heat shield, he noticed the actuator arm wasn't attached anymore. The circlip that holds the arm in place had fallen off, and the gate was stuck open.
Maybe check that?
hey guys,
been pretty flat out so i dont have time to look at the car. hopefully i can play with it soon, and ill get back to yous.
just got defected for my front tyre, so my car will be outta action for a little while, so that will give me time to look at it.
thanks again for all of your help, much appreciated!!!
cheers,
David
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
