As it sais
I just got a camera, i dont know anything about camera's.. i just wanted one that takes photos and doesnt have jibberish settings that i can take out wherever and start snappin!
I got a Sony Cyber-shot DSCS40
It's a 4.1mp camera with 3x Optical zoom and seemd pretty good for the price and its a point and shoot camera that will fit in your pocket which is what im after.
I got it for $290 delivered with 4x NiHM rechargeable batteries with charger.
I will get a memory stick for it off ebay as they damn cheap..
Did i do well?
https://www.sau.com.au/forums/topic/98497-i-just-got-myself-my-1st-camera/
Sorry to hijack your thread but what do you guys think of the Kodak z740 10X optical zoom with printer dock plus for $430 brand new. Is it worth getting any lens filters for it? And if you have used one what do you think of the picture quality? I don’t know anything about cameras and would just like to know if it is a good camera to get me started?
kodaks have horrible picture quality
You did ok. :P
<click>
A friend has a digital sony camera, I was quite impressed with the like like saturation it has. Very nice balanced photo's.
Don't buy HP their saturation is too high and tend to get a lot of noise in the back ground, i.e walls or darker areas.
Edited by Cubes
Get yourself a copy of Photoshop, or Paint Shop Pro at least.
MSpaint has horrible compression and quality loss.
I secont that.. MS paint and MS photo viwer are evil!!!
evey time you use MS paint to compress picture angel looses their wings...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
