not really pointless. When i was trying to get it working i would have payed someone just to give me straight answer as to whether they got it working or if it worked. And now everyone has a straight answer
YESS IT WORKS.
just make sure you use zener diodes that 666DAN sorted out. Make sure all connections are solid and make sure you use field harness and it is properly connected to ECU.
and asuming you have a emanage what are your thoughts on it compared to other aftermarket ecu's? wolf etc?
are there many benifits of the ultimate over the normal blue emanage, and do you recomend the full wiring loom kit or just the cut and solder kit? cheers
So is there still a coil issue even with the ultimate?
Well good news all you auto skyline owners the emanage ultimate works with the Automatic skyline Gearbox.
John keene from HiTech dyno centre got mine working!!!!!
WOOOOHOOOOO!
Excellent news.
How long has it been running for?
How many k's?
What's the dyno results look like?
:) cheers :O
PS; if less than a month and 1,000 k's it might be a bit early to jump. One ran for 2 weeks OK, then just stopped, dead coils and ignitor.
Guys as mentioned before the other option is now the bikirom megaboard, I've got one fitted to my current auto R34. www.bikirom.com
Should be good for stageas as well.
Great news Chris...I could tell from you e-mails you were starting to get stressed, which is understandable. At least it looks fairly promising now!
mad34 - what was the end cost of the Emanage Ultimate (installed and tuned)
666Dan - same question for you but regarding the bikirom?
SK - If the unit works initially without any faults, what would cause the breakdown after a few weeks?
The problem with the EManage to date has been its poor matching of the load and trigger signals to the ignitor and coils. Several modifications have been tried, including the voltage limiting zenner diode mod. This mod enabled the EManage to fire the ignitor/ignitors, so the engine would at least run. But there were still issues with dwell angle, impedance, decay time etc. So the ignitors/coils worked for a short time, sometimes hours, sometimes days, and they then failed completely.
Having heard success claimed several times, only to be disappointed, I don't think it's a good idea to jump in until at least a month and 1,000 k's or so have elapsed. If the engine still runs fine and performs perfectly after that time and distance, I feel we can safely use the product.
:D cheers :(
Dont say that guys i hope it works after 1000k's it should, it bloody better or i will shit bricks ;P. hahahahaha Dont make me paranoid!
Those zeners that 666Dan has sussed out will work as the guy who fitted it checked everything. he measured standard voltage and then voltage after the emanage was fitted and they were different. he said the zeners did fix the problem.
By the way thanks Again Dan.
Satanic-the cost of purchase and fitting was quite high around $1700. I still have to get pressure sensor and harness too so thats another $170 so id say all up $2000.
The Bikirom Megaboard will only work with series 2 NEO Stageas, the series 1 has a similar ECU to the R33, but i have inspected my ECU and found it has a external Eprom which the R33 ECU doesn't have, i talked to BadBiki and showed him a pic of it and he agreed that it might be possible to adapt the Megaboard to the series 1 stagea ECU.
Only problem is finding someone with the knowledge to nut it out, as BadBiki is too busy.
Anyone interested :D
Yeah Chris, car still going fine? I assmume it would be, my e-manage was running for over a year with no problems, worked so good someone stole it!!! (industrial espionage for sure haha)
Satanic - I've had the bikirom in for a little bit now, no dramas with compatibility whatsoever, I'll have a dyno graph fairly soon as Sam (Dr Drfit) will be in town, so I'll let him loose on my car.
My Cars ignition still breaks up a little when its warm and when i have been driving it hard. My std coils are on their way out. so i ordered some splifires they have arrived i just have to fit them now. also i have got the pressure sensor harness going in so i can run more boost without upsetting the afm. that should all be done in the next few days. i will let you all know.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
