Hey guys, i think its time to ugrade my stock intercooler, as ive bought a type m front bar for easier fitment.
Mods so far are just pod and exhaust
I'm wanting to get a full i/c kit inc piping so i can fit it all myself, and would like the hole where my standard i/c piping goes through to be free, so i can get some sort of cold air feed going on for my open pod (heat shielded), coupe r33 gts-t
My budget is ~ $1000, what would most go for with my budget?, i heard r33 gtr coolers are a great upgrade, but at the same time i was thinking a hybrid kit would do the job???just need some thoughts on the subjet.
Also, i bought one of those tubonet boost taps, but havent upped the boost yet as im waiting for the cooler to go on, whats a safe limit after upgrading the standard cooler.....around 11 psi?
thanks in advice
https://www.sau.com.au/forums/topic/98815-r33-gtst-intercooler-mod/
the hybrids seam to be a good kit and many people are happy with them and you would probobly get it a bit cheaper than 1000 and yes gtr coolers are good with custom piping 11ish i ok but running 10 and a little bit would be better otherwise the ecu might get upset.
For ease of fitement (Took me slightly over an hour) I would get one with the returm pipe that goes back under the cooler and uses most of the stock intercooler piping (Like the pic below) No cutting excetera required, Blitz make one that can be had for around $1000 off of nengun, there is one for sale on here too http://www.skylinesaustralia.com/forums/in...showtopic=98632 ARC makes one for a similar price also on nengun (They can be had else where but I am thinking of your budget) And AVO turbo world makes one for $1100
Edited by Bunta
Bunta:
No offence, but a few of things i do not like about that fmic;
1/ The return pipe appears to sit low.
2/ Due to its design the core is pretty small.
3/ No cold air feed for the pod, so you are only sucking hot air in the eng bay.
Those fmic kits are only good if you intend to keep your std airbox and have limited power.
thanks for the info guys, some dude down here is selling a hybrid kit for cheap, but im a bit concerned....he sent me the install inst. for the hybrid cooler, and it says that the fan blades need to be trimmed for the piping to pass through???it doesnt sound legitimate to me.....or is this what you guys had to do?
What kits are straigh bolt ons, no cutting etc required....id like to spend just under 1000....cheers
Alot of people have had to cut their fans.
I got a Hybrid copy piping kit from Justjap but my mechanic managed (very well I might add) to fit the piping so it doesn't hit the fans. He had the move the whole piping kit half an inch back.
Hey guys, ive got a price of 700au for a full hybrid cooler kit sent to my door, but a mate of mine will be able to source a r33 gtr cooler w/o piping for 350-400au.......bit of a crisis, how much would a piping kit cost me.....and is there any issues with fitment for the r33 gtr cooler on my 25t?
i dont know which way to go.....please help
thanks
ive been searching the forums, and find they're good for 300rwkw, so restriction is not an issue.
How about piping for these things, will it have to be custom?if so any instructions on how to fit a 33 gtr cooler to a gtst (33 also)?ive been searching but havent found any info so far!
mod the plenum (forward facing, hardly any piping, plenty of room for everything), or throw down the ubend over the engine (clutters things up, leaves plennum intact, cheaper)
i have front facing plenum
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
