I don't believe they will destroy the coil packs, but if you have standard coils irridium plugs will make them work harder. For the best performance with these plugs you probably need a set of split-fire coils and have your plugs gapped correctly. i.e. high boost smaller gap around 0.8 to 0.9mm. Standard boost then the 1.1 gap will work ok.
I changed to NGK irridiums about 4 months ago and had nothing but trouble, misfiring, hesitation in the mid rev range. The smaller gap solved the misfiring but the car just never reved the way it used to. This is because my standard coil packs couldn't handle the irridium plugs.
I recently changed my irridiums to NGK copper ®, gapped them at 0.9mm and the car runs like a dream. They will only last about 20-30k depending on how you drive, but for $20.00 for a set of 6 who's complaining.
If you feel that you need the better plug, best to stick with NGK platium. The only problem is they come pre-gapped so you need to order them with your preferred gap.
Paul.
umm, okay. So, should I be overly concerned about this? Does damage usually occur within weeks, or do I have a few months?
Its not really damage that occurs, it's just that they don't work as well. Especially if the coil packs are getting older this doesn't help. Eventually of course a coil pack will die. If you stick with irridums then use splitfire coils, around $800.00.
Paul.
in a good way thats good to know..when I bought my skyline almost 3 months ago, my mate made me buy the iridium plugs. Spend a fortune, then figured it was too much hassle to change them, on account of the ornament and piping covering up the plugs and coils..so they've just been sitting there in my garage for the last 3 months...
Hey can someone please explain why you guys are making the spark smaller??? I dont understand, really it doesnt make sence, well not for me anyway.
I thought the bigger the spark the better the bang?
also matty_tonkin Super cheap sell them, $20 for a set of 6
Edited by 7yphon
The deal with closing the gap is that with running higher boost the forced air can blow the spark out.
Which causes the car to go and sound like a heap of crap when it hits full boost.
I bought Iridium 0.8's for my car when it came over because even though running factory boost levels it wouldn't handle it when it hit around 5000rpm.
And plugs that were in it were Iridium 1.1's
but ive heard that compared to japan our premium fuel quality would be there everyday cheap stuff.
Thats what i know anyway, hope it helps. :)
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
