i recently purchased some decals for my car (the same as the ones in the attached image) and they have just arrived, seeing they cost close to $200 inc shipping the last thing i want to do is bugger them up, basically just asking if anyone has applied these kind of size decals to their car before or knows of anyone/company in adelaide who could help me with it, they did come with instructions but am not too sure about attempting it myself (worried about leaving air bubbles etc) thanks guys!
https://www.sau.com.au/forums/topic/99035-applying-decals/
I've done this before, you just have to do it really slowly. Make sure you paint is perfectly clean and dry, take off the backing sheet, lay a small corner piece on and then apply using something with a nice flat surface, like a credit card etc. Make sure you push the air out as you go, and the end there may be a couple of tiny air holes, get a pin and gently pop them, then slowly peel the top sheet off, again using the cridt card or what ever as you go, and presto it's on. Also a good move to rub over the decal with the card prior to fitment so it's stick properly to the top layer of paper, otherwise parts can end up staying on the bottom piece and totally f**king it up.
Best of luck mate
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1803619
sounds quite expensive for 400R/nismo style decals. but like mxtcy has suggested, take it real slow. patience is the key, in my opinion there is no need to take it to someone else to do it as its just going to cost you more money - i assume so anyways.
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1803735
spray windex on your car, put the decal on, move it into place and wipe down with your credit card to make sure it's all smoooooooooth, let it dry then peel top sheet off........IS DONE IS GOOD!
BINGO!! DONT do it dry 1 stuff up and its there for good kiss 200$$ goodbuy
i used to work @ olympic trailers and they used a simular method i think with just water spray to put there stickers on... u can get bubbles out with a rubber squigee
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1804536
cheers for the advice, gonna give it a go tonight with a mate, ill let you know how it goes :)
where did you get them from thirty four?
got them off ebay from a guy based in hong kong
https://www.sau.com.au/forums/topic/99035-applying-decals/#findComment-1804667
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
