Last week I had my GTR tuned on Boost98 for a dyno figure of 351rwkw.I used Boost98 after reading the article in HPI by Martin Donnon.
The car ran great with knock readings in the mid 30's,till the weather got hot,where I recorded low 70's.Nigel(Ice Performance) suggested we retard the timing 2 degrees and see what happens.Single digit knock,so we tried 1 degee retarted,where we got mid teens and left it there.The car is going back in for cam timing adjustments,so I just adjusted the timing in the settings screen,I had to do it every time I restarted the car.
Today,I was near a Shell servo that stocks Extreme100,so I thought I would fill up(47 litres) and test it out.I am now running 3 degrees advanced over the original setting on Boost98,thats 4 degrees more timing!!!!! and recording mid teens on the knock sensor.
I will be using this fuel on my next tune in the New year,highly recommended.
Between now and my next tune,I will try Ultimate to see how it compares.
https://www.sau.com.au/forums/topic/99217-boost98-v-extreme100/
There are 2 Ethanol fuels.E10 has 10% and is sold by United as Boost98 and E5 has 5% and is sold by Shell as Extreme100.
Dyno figures are bound to go up dramatically as we had 365rwkw and had to knock out some timing using the obviously inferior Boost98.The 100 octane Extreme looks very very promising,allowing 4 degrees of extra timing while keepoing the knock lower,should also allow a little more boost.
which shell servo was this m&m?
Cnr Warrigal Rd and Centre Dandenong Rd Cheltenham,near DFO.
There are 5 shell servos on Burwood Hwy and 1 in St Albans as well.
thanks for that.
burwood hwy is a bit out of the way for me, so i'll have to try my luck in st albans.
Generally you loose power with ethanol blended fuels, so you have to advance the timing to get some of the power back. The good thing is, with careful tuning you can get good gains over the regular 98 RON stuff.
New 100octane shell fuel with 5% ethonal is what you want. you will not lose any power , you will gain timing,response and power.
I did some research ito fuel octane and detonation and have to wonder why the ethanol was added . I sort of though that the alcohol helped to make any condensation soluble but I'm beginning to wonder if slower burning high octane fuels need a bit of help at the cold start phase . The mighty 3 cyl G11 ran like a hairy goat at the first cold start on the Shell 100 but runs fine on it now . If anything it make a little better part throttle torque and the choke (showing its age here) is never needed .
It will be interesting to see if the other flavours of 100 octane fuels will have ethanol in them .
Cheers A
  • 3 weeks later...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
