Hi all
I have got an Apexi pod filter. On the nengun site it says its a replacement filter.
There is no adapter, just holes in the back of the filter where the screws go in.
The part number is 500-A022.
I know that there is a kit for my R34, part number 500-N006. However this kit does not come with an adapter because the filter will bolt straight on to the AFM.
Question is, the replacement filter I have, will that just also bolt straight on?
What is the difference between to 2 parts? If there is no adapter in the Apexi kit, then shouldnt the 2 parts be the same? Or are there some other parts that I need?
Cheers all!
https://www.sau.com.au/forums/topic/99268-apexi-pod-filter-without-adapter/
it sounds like you bought the new paper insert for them and no i dont see that its going to bolt on to your AFM but you need the whole filter instead.yep thats what you did same numbers you should have got the power intake kit!
http://www.nengun.com/catalogue/product/115
507-N006
I pretty much have this:
With holes at the back of the filter for screws.
The nengun site says "The Apexi Intake kit includes. Power intake funnel, Adapter, Gaskets and Bolts."
I already have the intake funnel, gaskets and bolts. Just no adapter, but have been told an adapter does not come with the R34 kit because it doesnt need one.
Any R34 owners out there with a Apexi pod?
Mate ER34 and ECR33 are same part number.
http://www.perfectrun.com.au/performance%2...powerintake.htm
Since R33 GTS-T part comes with adaptor you must also need one for R34?
http://www.modyourcar.com.au/product_info....roducts_id=2607
There you can see R34 part includes adaptor.
A quick question though, why is there a different part number for turbo and non-turbo R33? What differences are there?
I have one of those HKS Super Power Flow 'mushroom' filters that looks like that when you turn it over. Mine didn't need an adaptor of any sort, just bolted straight on to the AFM. I'd assume the Apexi one is the same.
"My cat's name is Mittens."
the only thing the kit comes with as opposed to just the filter i believe is a metal bracket to hold the pod up.
i bought the kit and was dissapointed that this was the only difference when i could have got just the filter which bolts straight up.
so with the filter it will bolt straight up, it comes with a paper gasket that u put between the afm and filter.
if u dont have a bracket for it u will have to make one (easy)
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
