Hi,
I have step 1 hks cams now, stock valve springs etc
should i put cam gears? before i get it tuned, do you think they are worth it? what gains will i get from them?
why would you buy cam gears? who sells cheap cam gears? ( honestly i wouldnt spend more then 150$per cam gear :) )
cheers
Hi,
cheers
Yep - cam gears are definately a good idea as they turn the camshafts which in turn activate the valves in the head.
One advantage of not fitting cam gears, however is that the valves, springs and cams will last a very long time (perhaps forever?) and require little if any lubrication.
Perhaps the biggest disadvantage of not fitting cam gears is that the engine doesn't run without them, although this is also an advantage if good fuel economy is a priority to you.
Nope...the valves will actually last about half a second
Sorry - can only have so much "Christmas Cheer" before something has to give!
Yep - the benefits of adjusting cam timing is well documented and makes a huge difference on RB26 engines. The cost of these can be dwarfed by the labour and dyno costs if you want to tweak the power vs mid range torque tradeoff to your exact liking.
As others have said - do a search as there is plenty written on where a good starting point is.
Good luck
Gav
Yep! get em. I have a set of pond cams and I gained 80rwhp 900 rpm earlier! after diling them in on dyno. but lost 5 hp at top after doing inlet, and actually got 10 more hp at the top after doing exaust, so I ended up gaining top end as well.
Os Giken $300 a set. = bargin.
who sells them for 300?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
