okay...
Mechanical: The guage itself acts as the sensor... i.e. if you've got a Mechanical boost guage, the vacuum (boost) line will plug directly into the back of the guage, and this is used for the input for the readout...
Electrical: The guage gets its data from a seperate sender. I.e. in the example of a boost guage again, there would be a seperate sender mounted in the engine bay somewhere, that the boost line plugs into... the Sender then converts the boost pressure into electronic data, and transmits it to the guage, which then displays it for you...
So, in conclusion, if you're looking for things like Oil Pressure, Oil Temperature, Water Temperature etc, try and get Electronic, as nothing worse than driving along, and getting boiling hot oil squirted on your face if the line/guage fails or something.
(Well, thats my interpretation of things, someone feel free to correct me if i'm wrong)
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1811577
The only mechanical gauge I'd have is boost.
Another way to think about it is the gauge needs smething to detect what it's actually reading right? something that detects the temp/pressure/whatever.
In an electrical, the sender sits in the engine bay and sends an electrical signal to the gauge by a wire to tell it what value to display with the needle.
With a mechanical, you have to take whatever you're measuring and plug it straight into the gauge.. so your oil line has to go into the cabin to plug into the gauge. Ugly stuff.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1811659
anyone seen the price of electric fuel pressure guages??? they are like $900 from autometer...
and only $160 for Mech style fuel pressure...
so you definately pay for it. but the std ones like oil pres. and temp are still cheap for electric guages.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1813039
Cheers! thats pretty clear. i think that electric autometer one can stay in the shop. thats ridiculous. i also saw one that was liquid filled? whats the go with that. it sold for $60 on ebay. i thought that sounded like a sweet price.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1835336
Ouch. I would NOT pay a. for american gauges b. that much.
Greddy electrical gauges go for 180-200 second hand on the forums. Funnily I have a water one ready to go (black face) if anyone wants (shameless plug).
Nengun have them around $220-$280 brand new.
https://www.sau.com.au/forums/topic/99385-gauges/#findComment-1836104
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
