ok ladies n gents,
i am ready to fly..
I need tips n suggestions.. i want nothing under 300kw at the wheels for the start. this should hold me for at least 6mths b4 we tear the whole engine apart and add more.
i wanna start with that bullshit plastic front bar. it keeps scraping and is on the verge of falling off. what can i replace that with?
secondly, the car is goin into the work shop on tuesday to get ne air intake + filters and boost controller ( coz remember my baby was stock as a rock when i bought it with only 40,000km) the exhaust is on, the turbo timer is on, thats the basics down, the boost controller and filters will b dun by wednesday.
can we have an estimate of the hp/kw with those basics coz i cbf dyno-ing just yet..
https://www.sau.com.au/forums/topic/99717-help-with-my-modssuggestions/
300 kw at the wheels is a lot of power and your goin to need a lot more than a boost controller and an exhaust hahahahahaha. You need to spend a lot of cash to make 250 kw never mind 300kw. Try a computer, injectors, fuel pumps, adjustable cam gears, fuel pressure regulator, dump pipe, full exhaust and the list can continue to increase the power then you need the metal head gaskets, pistons, valve springs so and so just to handle the boost increase. Lets just say to get 300kw out of your RB20 your nearly running it at its full potential there only really good for a RELIABLE 400hp. Want anymore start looking at its big brothers.
ok ladies n gents,
i am ready to fly..
you would want to start with "tearing the engine apart" to support that power figure
thats a great start.Getting rid of that bullshit front bar is one of the first key steps to the magical 300kw mark
ok ladies n gents,
i am ready to fly..
change the turbo timer to a twin turbo, that should help.I estimate 299kb ...Dyno is used for tuning so you "should be f**ked" "dyno-ing" your gtr??
hey mate are you in vic? you should jump in the wasteland with that sort of consecutive posting...lol
nah man nsw just at work reading ridicilous questions, I didnt know how to quote a few replies in the same post
hehe fair enough, well if you want to do that, at the bottom of each post you want to quote, click the quote button, and it will turn red then after you have selected each 1 you want, click add reply and you're set
hows that
It is a GTR, 300kw at the wheels shouldnt be that difficult..exhaust. Boost controller, power FC and you could be somewhere close
done
Man, he's got a GTR. RB26.
lol.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
