Im still a beginner, but im learning fast. Is there anyone else here that does it?
I dont know amny 14yr that can actualy even figure out what all the buttons mean.
I know the basics.. and im still learning.
Anyway.
Here's a low poly V8 motor i made because i was VERY bored one day.
A sub i made within a few mintues.
A cool skatepark.
Last but not least, i work in progress, a Audi A4 im doing with a tutorial. It will be high poly by the time im finished with it. And also, the textures are crap, i havent botherd to UV wrap them.
Edited by Twitch
https://www.sau.com.au/forums/topic/100076-3d-modeling/
  • Replies 52
Posted Images
used to do 3d modelling ages ago, but I just don't have the time and patience for nurbing these days :D My software's like outdated by a couple of years too, which dosen't help.
Trendwhores these days just mish mash some polygons in maya or 3ds and then use it in photoshop or freehand... so not a fan of that sorta 3D.
https://www.sau.com.au/forums/topic/100076-3d-modeling/#findComment-1826268
HAHA, runs and hides.....
http://www.deviantart.com/view/19138768/
https://www.sau.com.au/forums/topic/100076-3d-modeling/#findComment-1826431
Ahhhhh but funky... remember your a trend whore yourself with your AE86 :(
What design area you focus on anyway funky?
Yeah before I went down the path of design I've already taken I thought I might want to get into 3d but nope... Personally found it too boring & there's not much work for it either, depends what kinda 3d too.
https://www.sau.com.au/forums/topic/100076-3d-modeling/#findComment-1855938
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
