  • Replies 318
you embarressed about going to WSID?
then u must not have much self confidence... and the street is nothing but bumps and holes!
can you do 160km/h+ easily on the street with no worry about hitting anything? its nothing compared to the smooth surface of WSID, once you try it you wont race on the street again!
my self confidence is fine thats what my shrink tells me anyway
its just not my zone brother
how come gtr has nothing to say now?!
Cause he is not really here...Ludacris rang him up and said "Yo got fo minutes man" so he ran out the front door of his house boat pulling on his tshirt as he went, hence forgetting to turn off his computer
no i'm not... but come to runs this saturday nite and i'll race the r34
are you coming to autosalon 2006 to compete against my aerotop supra with vertical doors, 1st grade leather interior, one piece mould veilside widebody and bodykit, 21" rims, $6000 sound system?
From the Supra Forums... and the car is owned by a GIRL...
As a joint project with hi power racing (www.hipowerracing.com) i would like to inform you with a tease of what i will be doing to my much loved supra in the months to come.
after waiting six months i finally get my front cut today, this takes so long as finding a supra damaged is near on impossible, but mission was accomplished with the help of ivan. Which means my car will be in one peice again   and no more jealous boyfriends are aloud near my car  pm for more details
as you know i have a gt300 wide body kit by topsecret, which will make her look like the beast she is, i have my keen eye on set of volk gtc face 2 (size will be determined when i get the body kit fitted on the car, so we can measure off set etc)
below is a little list of what is happening to the engine there is more to come but these are just the teasers, the rest of the modifications will be let known to people as they are done to the engine. Ps, this is not my wish list this is my engine list
Jun 3.2 L Stroker Kit, pistons con'rod crankshaft, crankshaft sprocket wheel,
valve lifter, shim, O/H gasket kit, and more too much to type will be put on to a base engine
followed by processing such as cylinder boring honing, crankshaft ASSY balance, valve grinding and much more.
As we are using a used engine the engine will be basically rebuilt, that is what ever is not getting modified will be like new. Add to this a T88 38GK Kit, intercooler kit, radiator, 1000cc Injectors, HKS F-CON V PRO ver 3, V PRO Base, fuel regulator, SARD 265L Fuel pump, Triple clutch, and this is only the beggining (do not have the patience of sitting here and writing out the whole qoute again as i am a lazy lazy person hehe  )
I am considering painting the car hot candy pink as pink is for fast cars and pink is a girls colour (my fav also)
Before meeting ivan at hi power racing i called many well known australian workshops to give me prices and quotes to which my dreams became shattered then earlier in the year when i met ivan my dreams became reality and now i am under way to having my dream supra.
If work goes well for me in the next few months you can expect to see the car up in autosalon 2006 as that will be the first day out, though plans are going accord i should have her before january (no rush as this is a project car) i will keep you posted with pictures and more posts.
Looks like you will have competition...
she got the go tho... :D
Edited by shaolin
Guest
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
