Hey Guyz and Galz
I have an R33 GTST Series 2
My problem is - I have some oil comming out of the intake pipe just before the throttle body.
We already have an Intercooler and 3" SS Zorst
I am after an aftermarket turbo that has roller bearings and steel wheel that will simply bolt straight up to the origional equipment otherwise i have to change everything!
I would like to get more power out of it, but have a race car for that anyway!
you thoughts and ideas would be great.
thanks
MadManz
Use the "SEARCH" button, heaps of helpful info as this topic has been discussed countless times. :blink:
Also with a turbo upgrade, you will need:
- fuel pump
- injectors
- progamable ecu (Wolf3D, Power fc, etc)
- HD clutch
- And a few others i've probably forgotten.
not heaps of oil but i want to fix it before it gets worse and puts oil all the way through the system.
and I am only running the stock boost.
I dont really want to spend $4000 on a turbo which the HKS site listed.
I am just after a good turbo that is steel wheel and roller bearing that is reasonably cheap as this is an everyday car...
I would prefer to spen 4,000 and have a supercharger hanging out of the HG's bonnet!
so just wanna get the skyline up and running with a slightly better turbo.
www.gcg.com.au its a direct bolt back on. take yours off, send to gcg, when it comes back fit it back on and its done. i would confirm how much oil its leaking before you go spend $1800 on a rebuilt turbo. wipe the oil away and clean the silicon connector and drive normally and check it again in a few days
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
