Hey Guyz and Galz
I have an R33 GTST Series 2
My problem is - I have some oil comming out of the intake pipe just before the throttle body.
We already have an Intercooler and 3" SS Zorst
I am after an aftermarket turbo that has roller bearings and steel wheel that will simply bolt straight up to the origional equipment otherwise i have to change everything!
I would like to get more power out of it, but have a race car for that anyway!
you thoughts and ideas would be great.
thanks
MadManz
Use the "SEARCH" button, heaps of helpful info as this topic has been discussed countless times. :blink:
Also with a turbo upgrade, you will need:
- fuel pump
- injectors
- progamable ecu (Wolf3D, Power fc, etc)
- HD clutch
- And a few others i've probably forgotten.
not heaps of oil but i want to fix it before it gets worse and puts oil all the way through the system.
and I am only running the stock boost.
I dont really want to spend $4000 on a turbo which the HKS site listed.
I am just after a good turbo that is steel wheel and roller bearing that is reasonably cheap as this is an everyday car...
I would prefer to spen 4,000 and have a supercharger hanging out of the HG's bonnet!
so just wanna get the skyline up and running with a slightly better turbo.
www.gcg.com.au its a direct bolt back on. take yours off, send to gcg, when it comes back fit it back on and its done. i would confirm how much oil its leaking before you go spend $1800 on a rebuilt turbo. wipe the oil away and clean the silicon connector and drive normally and check it again in a few days
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
