Hi all
Just wanted to let you know that I'll be up in Brisbane on Thursday, for a week....
will be looking out for Skylines so if you see a blonde girl waving from a POS hire car, that'll be me lol :lol: :lol:
planning on catching up with Gary for a drink, but doesn't look like there's anything much happening cruise wise?? (just checked your event section)
oh and I'm staying with my bro in Sunnybank Hills, which someone told me the other day is BOGAN CENTRAL....is this true!!!??? haha
https://www.sau.com.au/forums/topic/100392-visiting-qld/
Yeah sunnybank is full of asians... their arrows to turn left/right are bigger just so the asians can see them :P No joke!
It's really hot up here atm Shell.. like digustingly humid.
You should come to one of our Tuesday Chilli nights. Every Tuesday most of the regulars off sau head to logan hyperdome for dinner.
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1830248
nismogirl is right on the money
i live there its full of asians.
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1830258
Do this :rofl: Tuesday nite chilli is great :P And im sure you will have no trouble finding a lift :) If you cant get out there someone will swing by and pick you up!
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1830289
Is there such a thing as bogan asians?? This would explain Sunnybank very well....
Yep, called Eddies... Apparently. Dont get too many bogans driving round in porka cyane (sp?) turbos tho do ya.
Anyway, enjoy your stay up here. Wave to people with cefiros too, it freaks them out a bit.
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1830305
Come to chilli next tues.. loganholme.. about 15 mins drive south of brisbane.
Everybody likes to meet the interstaters .. it can even bring a crowd :)
You'll probably find a lot of the skylines only 'know of' sau, and don't play much part on here regularly, but there are quite a few about.
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1831512
LOL BOGAN CENTRAL
Bogan Central is anywhere in logan shire. and I hope you like BOGANHOLME too for your chilli nights.
Mains Rd is the joint to catch the skylines. And for you nismoGirl, bigger arrows... tsk tsk.. those arrows are for you because you have this big rice NISMO sticker on your windscreen that hinders your view. ONLY Joking. PM me please if you took offence =)
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1831573
Welcome to town. Chilleh is teh bestest. So many good memories.
Plus for a limited time you get this free frogurt! But the frogurt is cursed.
But it comes with your choice of toppings!....The toppings contain potassium benzoate.
Sorry, I just want attention.
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1832932
aww sounds good guys...chilli it is then :)
although I hope they have something else to eat cos I hate chilli :lol:
pred...there better be a crowd :D
mikey...slips back up there?? i thought he was in sydney?
Erin, do you still have the same mobile no? And thanks for the warning about the weather!! I'll pack light!!
LOL @ Asian bogans!!! can't even get a mental pic of that :P
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1833054
aww sounds good guys...chilli it is then  :D
LOL @ Asian bogans!!! can't even get a mental pic of that  ;)
Uhm.. I should do, I'll pm it to you anyway.
It's been horrible up here atm.. soo humid and yucky! I was glad to go back to work to get back into the aircon!
https://www.sau.com.au/forums/topic/100392-visiting-qld/#findComment-1833940
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
