Hey there just wondering if there is a way of changing the rings with out taking the whole engine out. i've been told u can access them by removing the sump..true?
Seriously doubt it. Haven't looked at an RB in that regard, but with an L-series engine (think of it as the RB's ancestor) it certainly can't be done.
Even if it were possible to ge the piston's out that way, getting them back in with new rings will be an absolute bastard......
https://www.sau.com.au/forums/topic/100695-engine-re-ring/#findComment-1837220
it can probably be done by pulling them out through the bottom end but i cant see why you'd bother unless you don't want to buy a new head gasket. I personally think it's a dumb idea. pull the motor out, pull the head off and do it properly.
https://www.sau.com.au/forums/topic/100695-engine-re-ring/#findComment-1837250
You have to take the head off because the pistons will only come out and go in through the top of the block. If you want to take them out the bottom, you will need to remove the crank. To put them back in through the sump, you need to get the ring compressor up inside the block - well nigh impossible, I reckon.
But, it isn't necessary to actually remove the engine from the car. Just raise it off the engine mounts to remove the sump.
https://www.sau.com.au/forums/topic/100695-engine-re-ring/#findComment-1838075
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
