hey guys.
my car (r33 gtst) isn't runing so good.
i swaped my stock AFM with a mates R33 (green lable, that works fine in his car) AFM, and it makes my car run like garbage, the car doesnt idle right, won't even go past 3k rpm in seccond gear. not good to drive at all
i cleaned my dirty AFM with eletrical contact cleaner, and now my car runs just like it did with my friends AFM.
whats the go?? i have 2 ecu's and they both dont like my friends AFM or my now cleaned AFM.
https://www.sau.com.au/forums/topic/100788-car-fussy-with-afm/
How did your's run before you took out your afm to clean it?
It may not be the afm you know, you could have a significant vacuum/boost leak in your intake piping which will give similar symptoms. Seeing as 2 ecus's dont like it and you've tried 2 afms i'd say you've eliminated both ecu and afm problems.
yea theres severe leaks, before and after the engine, its not good at all... as i said car running bad.
bad = 3/10.... that was with a dirty stock afm, any ecu (both arnt stock, but close enough to it)
with my friends AFM or my now cleaned one, its running really bad 1/10.
i just don't know why the good AFM's don't like my car??
The old
2 bads = running bad
compred to
1 bad + 1 good = running really bad
Happens all the time, the answer is to fix the remaining bad.
In your case the leaks are making the engine run rich. Less air is actualy going into the engine, so the ECU is supplying too much fuel.
This is partially offset by the dirty AFM which sends lower voltage signals to the ECU. Hence the ECU injects less fuel than it would if the airflow was accurate.
When you put a good (clean) AFM on, the ECU sees the correct (higher) airlfow and injects more fuel. The result is even richer running than when you had a bad (dirty) AFM.
The answer.....simple ...... fix the leaks.
Hope that helps
:P cheers :P
Edited by Sydneykid
hehe yea i know... fixing leaks cost money :P, and i also need someone to do it, which would require me to drive my car for at least an hour to a decent mechanic, and im not sure if thats good for the health of my car.... as it just pours black smoke out of the back.
but you have answered my question for now... so thanks
cheers
my cooler piping is fine, it was the first thing i checked. cheers paul. or anything else that i could get my hands onto.
mr mafia, wtf. maybe you could send your grandmar over here so she can lift out my engine. see now that would be somewhat helpful.
hehe, you spend your time bitching about me. and then you say im whinging. goodone jono...
Edited by hijaked
"car fussy with AFM" doesn't equal lazy.
however being currently unemployed is. reason to why i don't have money, also reason why its taken so long for me to get car fixed.
i wish it were a simple pipe leak. but i beleive its a intake manifold gasket..
question was purely about the AFM and it was answerd. i have no intension to come out as a smartarse, you have been on SAU longer and you are also older, so i must respect that. sorry jono
ok, well, I'd check those manifold gasket leaks that you are talking about, and then maybe look at a stuffed FPR or maybe one of your injectors is stuck, or leaking.
So the car is blowing black smoke on idle? It will if it is fuelling too much.
the car pours out the smoke on idle, its black.
the only reason i say manifold gasket, is because i can hear a high pitched air leak sound right at the front of the plennum, i dunno if thats normal, but i couldnt hear it on my friends car.
im gonna send the car to mechanic sometime soon, ive had enough playing around with it.
hopefully it wont cost too much to have the gaskets replaced.
but im sure the dude will have a look aroudn and see what needs to be done.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
