Hey ppls.
I got EPA’d again.
Performance Exhaust in Ringwood recommended replacing my Cannon at the back with a Magnaflow box.
Reckons with no other mufflers, this will make the car legal.
Anyone had any experience with Magnaflow?
Sound good?
https://www.sau.com.au/forums/topic/100843-magnaflow-mufflers/
  • Replies 65
hay bass they are not bad we (my dad and me got one made up for just for epa stuff) they are great and sound ok but just get a flang puton behind the cannon and get a stock muffler and bolt it on and then get it tested and when you get home change it over again.
I'll be putting in a flange so that when racing I can put the old muffler on just for aural pleasure.
I'll leave the Magnaflow on all the time, cos it's too loud in the car at the moment.
I HAD a stock exhaust and I lent it to HasLo on these forums.
It has since been fitted to his car for complience and then lent to one of his friends workshops who backed over it with a forklift, so I have no exhaust.
I want to reduce the noise of my car anyway, so the new muffler is the go.
...driving around in James' brothers WRX which has a Magnaflow cannon, it is still damn noisy for a stock car with stock exhaust apart from the muffler. Dotn know what model muffler it was...but i supose if you get one of their quiet exhausts rather then a 'performance' exhaust ????
Oh, and it's got a slightly offset muffler (Fujitsubo) in the middle
It's got a muffler in the middle AND one at the rear and it's still too loud. Damn they must not be much of a muffler.
What we do is fit a bolt in restrictor in the rear muffler, then it is a simple matter of undoing 4 screws and removing the restrictor. The restrictor is a reverse cone shape and makes the exhaust bounce outwards into the silencing material, rather than go straight through. With your access you should be able to make one up out of stainless steel pretty easily.
You trim the size of the hole in the restrictor until you get the desired noise level. Start of quite and gradually trim until it is at the limit. It does knock the top off the performance, but it is quick and easy to remove.
:P cheers :P
damn , i just fit a trust power extreme II about 3 weeks ago
theres a r33 power getter but no 34 so I guess its that . did you have to modify anything to get it to fit ? i had to mod my peII for the 4 door and that was a r34 exhaust anyway
strange that its loud , fuji are one of the quieter exhaust manufacturers around and my s15 power getter had no problems passing the pits .
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
