  • Replies 65
i have a 3inch front pipe, 4inch magic cat, and hks super megaphone catback, it has a large straight through 3inch muffler and is one of the quietest i have ever heard on a skyline.
edit: it also has a straight throughhot-dog style thing in the middle of it, but no real centre muffler.
Edited by siksII
ive got a 3" front system, with a split 2 x 2.5" after the "race cat pipe" to the rear with 2 x 3" mufflers.
Its one of the quietest exhausts i know, and doesnt drone. Its also mild steel.
if you want a quiet exhaust, make it out of mild steel. You will sell your car before the exhaust rusts off...
I followed the ford exhausts...why? Because they have 4lts, and a gt35r to shut up. And they did it with a split system...
Cats and mid mufflers dont mean jack to quieten an exhaust...
Edited by Bl4cK32
(R32 GTR, 330awkw)
I have:
HKS Exhaust Manifold
HKS Front/Dumps
DoLuck Cat + Cat-back with a 6" Canon
I got it tested last week and it was 120db at 3,500rpm. Not only was it extremely loud at idle (have Tomei Poncams too) but the drone was ripping my ears apart (especially when i'd done 4x 250km highway drives in the first 2wks).
I got a local exhaust workshop to replace the rear DoLuck canon (straight through pipe with baffling around the outside of the pipe) with 1 of their own. Their was a flange (4 bolt grr) right infront of the rear canon so it was just a matter of adapting the custom muffler to a 4 bolt flange and swapping it over (also had the entire cat-back raised 3-4cm). The result was 98db at 3,500rpm and absolutely no drone at all which is still way over the limit but i'm not sure whatelse could be done without making the car undrivable.
The annoying thing about this custom rear muffler was that its taken away the awesome "worked RB26" sound and also my power/boost is way down. I changed the rear custom muffler back to the DoLuck canon yesterday in the garage, pain in the ass 20min job. No point going to the drags with half your power stuck in the rear muffler.
I'd really love to get a whole new cat-back that is 1) 90db or less and 2) capable of flowing 330awkw but unfortunately I don't think it is possible. Having a 4 bolt flange on the entire system makes it very difficult to just swap over individual parts with other brands/models to see the difference as basically every but needs to be custom welded.
Edited by benm
Hey ppls.
I got EPA’d again.
You suck at teh not attracting attention to yourself.
That is all.
Maybe you should cut down on those bootycalls to adz's place in knox..
Bass,
Talk to your tuner about the Magna Flow mufflers, i was going to do the same thing but he told me to go jap and jap only, so i got an Apexi N1, its not to bad but still quite loud...
i suggested a few 3inch twin muffler systems but i think the attraction from the EPA your getting is becasue of your race cat, i have one as well and the car is quite a bit louder because of it.
I bought a silencer for it on long drives and it shuts it right up and still goes well, but not as well as without it!! just be careful you dont lose any power over the different exaust and have a chat to Ben about it before you chose a different exhuast...
I was just at a local exhaust shop speaking to him about my situation. Some interesting points he made:
- Their are 2 diff types of Magnaflow Cats, 1 has heaps of little 1mm holes and the other has 3mm holes. Provided you get the right size/volume cat it won't impact on flow only sound/noise.
- The rear canons (Jap) are nothing but a pretty hotdog which offer very minimal baffling.
- Their are 2 main types of baffling systems for the typical 'muffler (think; Lukey mufflers). The old style is where the flow pipe bends and twists around inside. The air/gases flow in a way to hit head-on with each other (effectively cancelling out on each other, hence reducing drone/noise but lots of back pressure).
The other type is basically a straight through pipe (enters 1 end of 1 side and exits the other end of the other size - sorta diagonal I spose) but has other parts inside the empty part of the muffler that do all the baffling. So basically the bigger the muffler you can fit under that rear bar the quieter it will be and better overall it will work.
Benm - you should go to a truck exhaust shop and get them to put a v-band flange on your removable section, then it's a case of one bult, a band and you're done!
my trust TR has V-bands and it is easy to remove the rear section :P
The power getters arent supposed to be quiet, I think thats where the Fujitsubo Legalis R  comes in. I had a listen to a few of the sound files on the Fujitsubo site and you can definately tell the difference between the PowerGetter and other models.
^^^ This is correct. Fujitsubo even include tested dB on their website. I can't find a listing for a Powergetter for an R34 GT-T, but here is the R33 GTS-t entry. For those that can't be bothered to click:
(Senario | Stock Exhaust | Powergetter)
Idling | 65 dB | 82 dB
Approach exhaust noise (4800 rpm) | 87 dB | 99 dB
3000rpm | 77 dB | 95 dB
5000rpm | 87 dB | 97 dB
4000rpm - 6000rpm response | 97 dB | 109 dB
The Super Legalis R is a much better choice (and considerably more expensive IIRC).
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
