Due to it being the Only Hatch Skyline to my Knowledge(and i want a Hatch) i have recently Came Across one that i like in perticular But Before Buying i was Curious If anyone Knew My Options My plans where as Follows:
L24 injected conversion To --- Any body know a Simple Conversion with 150 BHp easily obtainable Torque a Must.
the R31 to s13 coilover setup is this Just as Easy to do with the R30 to s13?
some Serious Camber How is this Obtainable with this Car?
Machine The Setup For the Castor Rods So that with added washed/spaces comes More CAMBER!
Bucket seats, remove Rear Seats and all Temp Gauges Neccasary
Further Forwared Positining of Lights With Better Globes.
Respray.
some R33 Tailights (rice i know *hangs head in shame*)
ANd watever else Comes To mind.
any ideas Are Welcome and Help Is also Very welcome i dono much about the Interchangability Of the R30 heard there similar To the Laurel
Edited by R30kc70UGE
https://www.sau.com.au/forums/topic/100951-r30/
I have one of these myself. I'll fill you in on what I know, from having done it, having heard about it, or having head about / done on another model Nissan.
Power Up - fit a R31 X-member, then any of the RB-series engines will fit. But that will require a new gearbox and modified tail shaft. Alternatively, an upgrade to a L28 (280ZX) engine, upgraded camshaft + extractors, might come close to what you are chasing.
Camber - By relocating the pickup point of the lower control arm, you can possibly crank some camber into it (but probably not "serious" camber). Others have been known to bend the strut at the stub axle connection (I think that's it, but never witnessed it)
You won't get more camber by changing the castor. If you fit LJ Torana castor rods IIRC, you effectively get adjustable castor rods, because the threaded section is too long.
Hope that gives you some ideas.
https://www.sau.com.au/forums/topic/100951-r30/#findComment-1843371
mate, some of the things your looking to do are an ask, unless you have $$$,
Engine swap with torque?? L24et, L28et, rb30et perhaps but the rb30 may site too high to close the bonnet, you may want to look into a vg30et ($$$) or a rb30de if you don't mind N/A..
Camber, correct adj strut tops for an r30 are a great start plenty of camber there, depending on the amount of chamber you are looking for and the tyre budget you have. you can always change other components later.
seats you can transfer the hr31 seats to the r30 rails but they will sit higher than normal, $250 will get you a brand new seat rail that is lowered and you can mount any aftermarket seat on them, mine arrives in the next few weeks for japan, you can get a recaro one ordered at autobarn for $400.
the rest your asking about are things you don't need advice on, removing the rear seat is what, undo bolts and remove.
the r33 lights ??? your better off looking for a set of HR30 hotplates or DR30 ones as it would cost more to convert the wiring and fit the r33's than its worth, couple of hundred at the most to get a set of DR30 tail lights from japan, or even here, that are in 100% A1 condition, then you just put them in no mucking about..
heres a link to a set for sale on ebay
http://cgi.ebay.com.au/R30-Skyline-Hot-Pla...1QQcmdZViewItem
i think you'll find the laurel is more r31 than r30 if anything..
Edited by rsx84
https://www.sau.com.au/forums/topic/100951-r30/#findComment-1843373
Need more positive castor not statric negative camber , that way you get the negative camber only when you need it ie when you turn the wheel . Much cheaper , much more effective . Ask Stu Wilkins to get some real ones made from the right grade steel , substitutes have been known to break and when they do its curtains in no uncertain terms .
BMW started this caster trend with E30's which were the M3's raced out here many years ago - it works .
https://www.sau.com.au/forums/topic/100951-r30/#findComment-1887383
Can you pM me more On this castor Info, where to get them made up, how Much castor they give and so on and so forth?
Made from 60T steel whatever that is and fitted to any serious Datsun rally car .
When you increase positive caster both wheels assume a camber in the correct direction . Outside wheel goes negative and inside goes positive which is what you want . What happens when the wallys use heaps of static negative camber and little positive caster is the inside wheel (relative to the corner) stays partially negative , so only about 1/3 of the available tread width is on the deck and not using its full grip potential . This shows up as unevenly worn tyres on the inside because when the outside tyres grip threshold is reached the inside tyre is dragged across the tarmack in understeer mode .
I use 1/2 deg negative camber and ~ 6 deg positive caster , I have 205/55/16 front tyres on my DR30 and 225/50/16 rear tyres and the front easily outgrips the rear . The limit of positive caster is how heavy you can stand the steering being . At 6 mine is reasonable with pwr steer but not so hot for armstrong power steer !
Most modern cars use lots of positive caster which is why they have neutral or even positive static camber and they don't understeer off the road like the old dinosaurs did with positive camber . Easy fix this because you don't need the dramas of adjustable spherical bearing strut tops just the adjustable caster rods and a wheel alignment . Turn in is brilliant for an early 80's car . Also have the toe set to 0 ie no in or out . Noltec or nolathane caster rod bushes are good as well .
Cheers A .
https://www.sau.com.au/forums/topic/100951-r30/#findComment-1888319
  • 3 weeks later...
A,
Stu Wilkins doesn't have any, cause I have had them on order foir months and months, but they are coming he assures me.
I will post when I know they're available and polyurethane bushes are a must with his style of adjustable caster bar. Stu's castor bars are about $180.00 pair.
For interest, I can get chrome plated adjustable caster bars made, special order for about $350.00 pair, same as attachment, like Jenesis does in Japan.
I can do these bars for a bit better but would need about 6 pairs on firm order if interested.
D
https://www.sau.com.au/forums/topic/100951-r30/#findComment-1931630
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
